R-410-a - HVAC - DIY Chatroom Home Improvement Forum
Old 11-17-2010, 11:03 PM   #1
R-410-a
What is the proper way to top off a new R-410-A CONDENSING UNIT
egrider is offline   Reply With Quote
Old 11-17-2010, 11:08 PM   #2
Do you have a txv or not?
DIY_HVAC is offline   Reply With Quote
Old 11-18-2010, 02:19 AM   #3
By superheat and subcooling press and temp.
hvaclover is offline   Reply With Quote
Old 11-18-2010, 04:36 AM   #4
An old Tradesmen
Rewards Points: 6,836
With a new R410A matching indoor coil.
Measuring the line set length, and adding the manufacturers listed amount of refrigerant for that line set length and matching coil.
Then checking both super heat and cub cooling to manufacturer's specs. And adding or removing refrigerant as needed.
R410A should be added as a liquid.
