Quietest Oil Boiler? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-14-2013, 09:39 PM   #1
Quietest oil boiler?
I am in the process of buying a house and waiting for the closing to happen. The current boiler is one of those low-efficiency tankless coil type, and since it's in a room right across from a bedroom, noise is even a greater concern for us. From what I gathered on the Internet, the Kinetics Energy system 2000 seems to be one of the quietest boilers out there, but it's also very expensive. What do you guys recommend? Does anyone here have system 2000 and like it much?
Thanks!
sunlight33 is offline   Reply With Quote
Old 04-15-2013, 06:25 PM   #2
An old Tradesmen
Rewards Points: 6,544
All the System 2000's I've seen use a indirect water heater. So it takes up a fair amount of space. Do you hve a lot of room.
Old 04-15-2013, 07:03 PM   #3
There is an empty space in the room enough to fit a 50-gal water heater, if that's enough. I think it also has a stackable option.
New Boiler for an Office - Got Two Quotes, but What Do We Need? Prolow Plumbing 0 09-17-2012 07:10 AM
Setting the reset "Curve" for a modulating boiler (modcon) mknmike HVAC 5 02-10-2011 12:37 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 03:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
Boiler size Bonnie Youngs HVAC 29 07-10-2009 08:58 PM
