Questions For Doc Holiday - HVAC - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 12:32 PM   #1
Rewards Points: 292
Questions for Doc Holiday
Hi Doc. I've read your many posts regarding Rheem Mods and since you are the man, I have a few questions for you.
I'm thinking about DIYing adding a humidistat to enable DOD on my RGFD furnace.
1) Regarding the (sort of reddish-purple) tab on the control board which must be removed to enable DOD, can one simply grab it with needle-nose pliers and gently pull straight back?
2) What if any affect, does the h-stat have on blower speed in heating? Is it necessary to turn the stat to off, which I assume would keep the circuit closed?
3) If down the road, I wanted to remove the h-stat, would installing a jumper between R and DEHUM restore the board to its original function?
I currently don't have a humidifier, so would be wiring h-stat to R/DEHUM.
Thanks for your input.
V
veesubotee is offline   Reply With Quote
Old 05-22-2011, 12:39 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Tw
it.
Doc Holliday is offline   Reply With Quote
Old 05-22-2011, 01:38 PM   #3
Rewards Points: 292
Tw
.ad inf.
it????????????
Old 05-22-2011, 06:51 PM   #4
An old Tradesmen
Rewards Points: 8,228
A humidistat connected for DOD only has an effect on blower speed in cooling/dehumidifing mode, no effect in heat mode.
Old 05-22-2011, 06:59 PM   #5
I was going to say to stick his tongue across the contactor at the condenser to see if it still powers the board but what you said works.
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 02:37 PM
Basic (hopefully) electrical questions k2000lbs Electrical 10 04-27-2011 12:59 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 12:36 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 05:06 PM
