Old 07-10-2008, 01:52 AM   #1
Questions on assembling b-vent pipe
I've noticed that the b-vent pipes are designed to snap together tightly. Do you still need to fasten them together with sheet metal screws?
Also are b-vent products from different manufacturers compatible? The local HD has American Metal Products, but they do not have some of the lengths I need and I may have to go looking at other stores. If, say the local lumberyard has b-vent piping from a different vendor, could I still use it with American Metal Products pipe?
darsunt is offline   Reply With Quote
Old 07-10-2008, 06:31 AM   #2
coolmen's Avatar
you must use the same brand. your not suppose to screw into b vent pipeing however the duravent pipes sometimes are very diffacult to turn to lock so i would use screws at the connection. the other type of b vent witch locks in place when pushed together and with a locking ring i dont screw in place. when secureing the bvent with metel hangers or straps I will screw to secure. I feel that if he chimney was not secured and falls or breaks at the seam some one could seriously get hurt.
coolmen is offline   Reply With Quote
Old 07-10-2008, 04:32 PM   #3
It is against code to screw into b-vent this goes double for all-fuel (oil) the reason is if the wall is penatrated it will transfer heat out and is a potential fire hazard .If secured with the proper hangers in the proper intervals you dont have a thing to worry about
geo fan is offline   Reply With Quote
Old 07-15-2008, 11:16 PM   #4
The present vent system expands from 3" pipe to 4" pipe. Is this necessary?
By the way, it is from a water heater.
Vent pipe, 2 questions moneymgmt Plumbing 14 12-06-2012 11:37 AM
Septic Tank Vent Pipe ddave23 Plumbing 29 07-18-2011 01:21 AM
framing conundrum: 2" PVC vent pipe going horizontal through 2x4 studs amakarevic Building & Construction 18 01-19-2008 07:47 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
