Questions About Repairing Old Wall Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 02-03-2009, 12:09 PM   #1
Rewards Points: 682
Questions about repairing old wall heater
I have an 4' X 2' direct vent wall heater. It is mounted on the wall and the vent goes right thru the wall to the outside.
Is it better just to replace the whole unit instead of just the gas valve? The gas valve hasn't worked in a year, but I understand a new gas valve can cost 2 or 3 hundred dollars, while I can buy a new furnace plus the valve for about 500. I'm thinking the old burner might be old and rusty with a bad flame, and I don't want to reuse the old pilot and burner gas lines.
Is mounting these direct vent wall heaters pretty standard? Do they have basically the same dimensions, use the same sized hardware for the venting pipe? I believe the top vent wall heaters are pretty standardized in that way.
darsunt is offline   Reply With Quote
Old 02-03-2009, 02:49 PM   #2
JohnH1's Avatar
If it a Williams for a Williams or Cozy for Cozy you should be a exact replacement. But always double check.
JohnH1 is offline   Reply With Quote
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 03:50 PM
