Questions About My Tired 30 Yr Old AC - HVAC - DIY Chatroom Home Improvement Forum
Old 06-21-2009, 12:43 PM   #1
Questions about my tired 30 yr old AC
Hello,
Newbie here grateful for any help
I just bought a house with a tired 30 yr old AC compressor / furnace / blower and am having some trouble (as one might imagine).
Of course it all needs to be replaced but I'd like to try and get one last season out of it before replacing it.
First question...I've noticed the built in crown a40 autoflow manual humidifier is sweating badly as is the "cold" line.
I want the house as dry as possible and can't figure out how to turn the humidifier off...and am wondering if a humidifier can also act as a de-humidifier. The control settings for the A40 indicate settings from A - E + a DRY setting with a chart suggesting E for "+20" temp and A for "-20" temp.
Any thoughts or advice?
Gratitude,
~Shinsundo
shinsundo is offline   Reply With Quote
Old 06-21-2009, 01:26 PM   #2
as seen on tv
Rewards Points: 150
Turn humidistat to off you are trying to remove humidity with a/c
qbert is offline   Reply With Quote
Old 06-21-2009, 03:59 PM   #3
Good money after bad. Why spend several hundred on a repair when a new unit can save you money and give you a tax credit.
hvaclover is offline   Reply With Quote
Old 06-21-2009, 06:46 PM   #4
An old Tradesmen
Rewards Points: 6,098
No, that humidifier can't be used as a dehumidifier.
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 03:37 PM
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 03:23 PM
When to sand and other questions... PaintedSurface Painting 4 03-27-2009 10:13 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 06:06 PM
