Questions About My Return Plenums - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2012, 01:25 AM   #1
Rewards Points: 150
Questions about my return plenums
Soundproofing Air Return Plenum. I have 2 air return plenums in my basement and they echo and vibrate something aweful. What can i do to sound proof them or at least stop the echo/vibration. I'll be decoupling the ceiling so that'll help but still. Also, they're nailed flush to the joists but is it ok to seal them to the joists as well so there's no leaks whatsoever.
Thank you.
Mijotter is offline   Reply With Quote
Old 12-01-2012, 03:16 AM   #2
Rewards Points: 6,652
Some use sound mat that is used in cars for dampening noise.
The Following User Says Thank You to gregzoll For This Useful Post:
Mijotter (12-07-2012)
Old 12-01-2012, 05:02 AM   #3
An old Tradesmen
Rewards Points: 6,902
Looks like panning. If it is, you might want to remove it, and then replace it with thermopan.
The Following User Says Thank You to beenthere For This Useful Post:
Old 12-07-2012, 12:17 PM   #4
Rewards Points: 150
Thanks guys for the input. beenthere I looked at your idea of the thermopan and it's perfect. and a lot more cost effective. Going to replace both plenums with it and thankfully my local Menards has the pans in stock
Tags
ceiling , duct , plenum , sound proof , soundproof
return air general questions BlueBSH HVAC 2 10-07-2011 08:46 PM
Moving cold air return in basement djinlondon HVAC 1 09-28-2011 10:15 AM
Help with hvac return duct gasbie HVAC 3 06-19-2011 10:44 AM
Question(s) about returns veesubotee HVAC 1 12-05-2009 10:38 AM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 01:44 PM
