Questions About Installing A New Thermostat - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-23-2013, 03:17 PM   #16
I have extra wires available in the bundle. I need one to run a C wire, as the new tstat stays lit, and also uses WiFi. Since I have an additional wire available I guess I'll try it and see if it makes a difference.
Yuri, thanks for the tip about checking the electrical section in the manual. I found a diagram in the manual which shows that if I use W2, "if wire is connected, dip switch No 1 on furnace control should be set to ON position to allow thermostat to control furnace staging". The dip switches are clearly marked 1, 2, 3 and off/on, so I'll flip #1 on and give it a try. If I don't like it, or don't notice a difference, I'll switch it back.
Thanks for all the advice, all! I've never done any of this before, but I'm learning a bunch!
miscrap is offline   Reply With Quote
Old 09-23-2013, 03:23 PM   #17
Hvac Pro
yuri's Avatar
Rewards Points: 2,238
Have fun flippin your dips.
Apparently you are supposed to make sure the furnace is NOT calling for heat after flippin it and on it's first startup. Like a computer which it is it checks those dip switch positions and burns them to memory. If it is calling for heat it will use the old position irregardless of the new switch position.
I do mostly Lennox and did tons of those Carriers also.
Old 09-23-2013, 03:56 PM   #18
Meaning I have to run an a/c cycle first?
Old 09-23-2013, 04:02 PM   #19
An old Tradesmen
Rewards Points: 7,278
No, just have the power turned off to it when you switch the dip.
The Following User Says Thank You to beenthere For This Useful Post:
miscrap (09-23-2013)
Old 09-23-2013, 04:48 PM   #20
Hvac Pro
yuri's Avatar
Have the tstat set to OFF, not heat or cool or fan ON and power OFF when flipping the switch. Nothing must be asked to run when you first power it up. That is also good practice when starting any furnace after changing a board.
The Following User Says Thank You to yuri For This Useful Post:
Installing New Shower - Multiple Questions timidir Plumbing 7 02-13-2013 11:33 PM
Questions on installing a bathroom vent on a Mansard Roof GaryGday Roofing/Siding 3 08-31-2012 10:46 AM
Having trouble installing a new thermostat Khaos2639 HVAC 17 08-03-2011 08:48 PM
Installing unfinished wood flooring, and have a few questions. 240sx4u Flooring 2 01-19-2011 03:25 PM
Installing new thermostat Jarhad HVAC 1 02-28-2010 02:39 PM
