Old 08-26-2008, 01:34 AM   #1
Questions about high velocity air?
I recently saw something on DIY channel and they were installing a "high velocity" air conditioner.
What is this about?
I'm looking to get a new air handler and heat pump for my 2500sq. ft. house in Florida and thought I'd like to learn about this setup.
imola ghost is offline   Reply With Quote
Old 08-26-2008, 11:33 AM   #2
There a several differnet manufacturers, but here is a link for one that may give you the info you want. Hope it helps. http://www.spacepak.com/index.asp
statman is offline   Reply With Quote
Old 08-28-2008, 03:11 PM   #3
Res Ipsa Loquitur
Another is Unico Systems http://www.unicosystem.com/
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 12-07-2008, 07:07 AM   #4
Unico & Buderus
I know this is a rather old post - but I have a Unico Air Conditioning system installed in our home. If you have questions about its operation just ask.
donimbimbo is offline   Reply With Quote
Old 12-07-2008, 07:36 AM   #5
An old Tradesmen
If he already has a conventional system.
No use ripping out all his duct work. And removing all his existing supplies.
And running everything new.
A VS blower, can give him the same humidity control as a HV system.
Old 12-07-2008, 11:03 AM   #6
Unico & Buderus
slow down beenthere - I'm just willing to answer questions about our install. Not suggesting that anyone rip out their current duct work and switch.
Old 12-07-2008, 11:11 AM   #7
An old Tradesmen
LOL...
Well, hopefully by now, he has his new system installed.
My response wasn't aimed at you only or specifically.
Best High Temp Paint for wood stove?? Sellncars Painting 9 01-21-2009 07:21 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
Old refrigerator = high power consumption? RammsteinNicCage Appliances 6 06-13-2008 11:50 PM
Questions on new heat pump? JoeFL77 HVAC 3 05-27-2008 05:58 PM
Tub Surround, Painting, Durock or Greenboard, and Spacking Questions? golfer2b Plumbing 7 04-17-2008 09:59 PM
