Old 02-02-2009, 08:13 AM   #1
Default Questions about duct system
Am trying to maximize temperature at register in a room. Am using a probe thermometer and noticed that the temperature would rise a couple of degrees after I had inadvertently closed down the register somewhat.
Since there was little change in air flow, does it make sense to use this technique (close down slightly) on any/all registers? Would it increase throw? Effect on static?
All dampers are wide open, or nearly so. System is quiet, runs 2 - 3 cycles per hour, depending on outdoor temperatures. Just that 1 or 2 rooms on north side sometimes cool.
V
veesubotee is offline   Reply With Quote
Old 02-03-2009, 12:10 PM   #2
Close the registers in the south rooms.
You can probably close them completely during the day, then open em at night (if you have the inclination to do that extra work).
If not, just close them partway. Open them back up in the summer.
Garasaki is offline   Reply With Quote
More On This Topic
When it comes to selecting a digital thermometer for home use there is a number of choices on the market and it comes down not only to issues of price and how much your willing to spend but also it's a general assessment of which thermometer type is... Read More »
So when it comes to selecting where to use a digital thermometer, again, oral thermometers are for use in the oral cavity or you can also use them under the armpit. That can be a convenient way of taking a temperature in a younger child when your only... Read More »
Tortoise Cage Thermometers
Tortoise Cage Thermometers by Expert Village
The next thing we're going to talk about, after since we've already spoken about heating, is how to gauge your heat, and for that we're going to need a thermometer. Now, you can't trust yourself to gauge heat. You can't put your hand in there and be like... Read More »
Okay. So we're talking about placement of our thermometers which is important. Generally what you want is you're going to want one thermometer on the higher end of the aquarium underneath the heat lamp, okay. What that's doing is that's telling you the... Read More »
Using Oral Thermometers
Using Oral Thermometers by Expert Village
So, we're going to embark upon the simple task of taking an oral, digital temperature now. I'll be using myself as the guide, or as the example rather and I'll be guiding you on how to do as such. First of all, if you haven't done so prior to your own... Read More »
Replacing 30 yr old duct... couple questions bigburb HVAC 7 06-11-2009 07:26 AM
System change questions javan HVAC 25 09-17-2008 01:29 PM
Openings in air intake duct on central HVAC system Omegazz HVAC 4 07-02-2008 11:01 PM
Clean Duct System? Devil505 HVAC 9 12-07-2006 10:33 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 12:56 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
