Question(s) About Returns - HVAC - DIY Chatroom Home Improvement Forum
Old 12-05-2009, 09:55 AM   #1
Rewards Points: 292
Question(s) about returns
There is a lot of emphasis on having adequate return air and possible remedies. So let me add to the questions.
With regard to grills, if the duct remains the same, what is the effect of adding a grill with greater free area? Lower velocity through the return run, or is that seen only at the grill? What about a second grill (different location) added to the existing run?
When adding a new return run, must it be connected at or relatively near the end of the return trunk or at the plenum? Where questions have been asked about the feasibility of adding a supply branch to an existing branch, the response has always been not to do it as it might negatively affect the original supply. So would doing so with a new return be a no-no?
Thanks for you input.
V
veesubotee is offline   Reply With Quote
Old 12-05-2009, 10:38 AM   #2
An old Tradesmen
Rewards Points: 7,372
Adding to the existing return could effect it negatively. Depends if the existing return grilles are sized right or not. If they are undersized. It won't hurt.
often best to run to the plenum. But not always practical.
Increasing return grille free area, is always a plus. It decreases the return static the blower must work against. And often increases the supply air flow(VS blowers can be an exception to increased air flow).
By checking the current static pressure in teh return duct. You can tell if adding to it will hurt or hinder.
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 02:37 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 12:36 PM
Questions for experts. Tech08 HVAC 9 01-25-2009 12:47 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
Reducing size of very large air-vent returns in floor? AllGoNoShow HVAC 3 09-19-2006 09:36 PM
