Question Regarding Installation Of A New Line Set For 410A - HVAC - DIY Chatroom Home Improvement Forum
Old 04-29-2012, 09:05 PM   #1
Question Regarding Installation of a new line set for 410A
For new home construction, it is common for HVAC contractors to install the line set weeks/sometimes months in advance of the air conditioning unit. Is it not proper technique to seal the line set and even leave a small nitrogen charge to prevent air and moisture inside the line set?
Duncan Russell is offline   Reply With Quote
Old 04-29-2012, 09:09 PM   #2
Rewards Points: 614
I personally would not install a line set that far ahead.... if you do it should be sealed .. nitrogen really not required at this point unless piping getting covered and you want to ensure pipes not leaking... i.e. dry wall screw
carmon is offline   Reply With Quote
Old 04-29-2012, 09:14 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
That depends on how it is routed, but its not that uncommon here as building schedules vary. A contractor get an allotted time to do their work and then the next contractor gets their time. It works this way to keep the process of building organized and so contractors are not stepping on each other. The lineset should be sealed though.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-29-2012, 09:43 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
Very common and usually because we can get the entire system on the inside installed well before the electricians can get an electrical service let alone circuits run, usually weeks to months before. No need to set the condenser until the home is on it's final inspection as on a construction sight it will walk off.
I've taped the ends off but never nitro filled. New nitrogen and an evacuation will be fine come time.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 04-30-2012, 07:22 AM   #5
Rewards Points: 1,214
Yes, many builders install the lines during the building process. Years ago we used to install precharged lines in hundreds of houses while they were being built then when they were complete we come back and install the condensers and finish the heater room. Remember the lines were precharged and sealed.
COLDIRON is offline   Reply With Quote
Old 05-05-2012, 10:59 PM   #6
The line set should definitely be sealed and pressurized with dry nitrogen. Reason being is 410A refrigerant with its POE oil is way more susceptible to moisture problems than R22.
gumptown is offline   Reply With Quote
Old 05-06-2012, 05:47 AM   #7
biggles's Avatar
line set installers might just be that...with nothing to braze fittings,nitro and regualtors just slam them in an go to the next,even just tape as mentioned or crimp the ends would be an effort in the right direction.
Old 05-06-2012, 07:22 AM   #8
Never seen just " Lineset Installers".
Level Line for Baseboard installation williamwiens Carpentry 20 02-13-2011 12:08 AM
Schluter Ditra installation question epsilon Flooring 3 09-25-2010 10:34 PM
2 line jet pump question easygoin4 Plumbing 6 08-06-2010 08:01 AM
Installation of Granite Tile On Shower Walls Spacing Question. taras1 Building & Construction 2 08-04-2010 12:48 PM
Tile installation question pjpjpjpj Carpentry 7 09-21-2008 12:29 PM
