Question Regarding HeatPump Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 06-23-2010, 10:42 AM   #1
Rewards Points: 392
Question regarding HeatPump wiring
I have a Goodman heat pump and I'm trying to understand what the point of the white wire is on the heat pump.
I know the Blue (B) is common.
The Yellow (Y) is the main On/Off for the compressor/fan
The Orange (O) is the reversing valve
The Red (R) is the 24v supply
What is the White (W)?
I have a vision pro 8000 and it has it's own outdoor thermostat. I have my two stage furnace wired up as single stage with W1 and W2 wired together on the furnace and the AUX/E wired up on the thermostat. I currently have the white wire on the HP going to the W1 and W2 on the furnace.. Is this right?
Can someone help me understand what the HP does with the W wire?
zootjeff is offline   Reply With Quote
Old 06-23-2010, 12:53 PM   #2
W get's energized when the HP enters a defrost cycle. That will call for fossil heat from the AH during the time the HP is thawing itself out. (it enters A/C mode during defrost)
Personally I didn't even bother hooking it up. A few minutes of cool air during defrost isn't that big a deal but you'll get more comfort hooking it up.
hennyh is offline   Reply With Quote
Old 06-23-2010, 02:02 PM   #3
but another link says there is no universally agreed upon rules for wire colors.
Last edited by beenthere; 06-23-2010 at 05:04 PM. Reason: Removed link to another DIY site
Old 06-23-2010, 02:55 PM   #4
That's a very good point. Color alone should not dictate any wiring decisions. The wiring should be confirmed by physical inspection at the appropriate terminals.
Old 06-23-2010, 05:04 PM   #5
An old Tradesmen
Rewards Points: 6,132
Don't post links to other DIY sites.
Question about AFCI and Ontario code as well as some other general wiring queries drunken0monkey Electrical 5 06-15-2010 10:49 AM
Yet another subpanel wiring question Chris_M Electrical 6 06-10-2010 06:12 PM
mini split Wiring question??? mjebril HVAC 5 08-02-2009 07:31 PM
Attic wiring question everyman Electrical 4 07-07-2009 10:47 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
