Question Moving Vents - HVAC - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 02:31 PM   #1
Rewards Points: 150
Exclamation
Question moving vents
Changing some things in my HVAC ductwork and have a few questions(this is all in the basement btw:
1. What's the best way to seal off a supply just use thermopan?
2. I'm also moving a return. What is the best way to cut out a new vent hole in the return trunk?
Mijotter is offline   Reply With Quote
Old 03-23-2013, 08:22 PM   #2
Rewards Points: 150
anyone?
Old 03-23-2013, 08:29 PM   #3
Rewards Points: 14,306
Are you trying to close of a round steel trunk line, flex line, is the line gone and there a sq. or rectanguler line your trying to close off.
What type line are you trying to tap into? Material, shape?
Old 03-23-2013, 11:54 PM   #4
Rewards Points: 150
yeah it's a 6 inch sheet metal round supply run i'm closing off. goes right in the the trunk.
The return I'm moving will be to the sheet metal rectangular trunk return.
Old 03-24-2013, 03:32 AM   #5
An old Tradesmen
Rewards Points: 8,184
Use a 6" cap. Thermopan is not intended or approved for use on the supply.
Old 03-24-2013, 12:51 PM   #6
Rewards Points: 150
ok those caps. Are they at a local Home Depot?
Old 03-24-2013, 01:12 PM   #7
An old Tradesmen
Should be.
Old 03-27-2013, 01:01 AM   #8
Rewards Points: 150
I want to close it off at the trunk so that there is no supply line whatsoever. Is this where the 6" cap goes or should I just get a piece of sheet metal and seal over the hole at the trunk? Thanks.
Old 03-27-2013, 04:28 AM   #9
An old Tradesmen
Generally when I seal off a supply branch. I remove the pipe from the take off on the trunk, and use the cap to seal off the take off.
If you ant to remove the take off. You can use sheet metal panning to cover the take off hole. But its more work to do it that way.
Old 03-28-2013, 03:37 AM   #10
Rewards Points: 150
So I closed off a supply and moved the return with great success. A question; When the furnace kicks on I can feel a slight touch of cool air at the return vent. Is this normal and just the air getting sucked up in to the vent? I went upstairs and felt the same in the return there too. Thanks for all the help and advice.
Old 03-28-2013, 04:21 AM   #11
An old Tradesmen
Common with many systems.
Old 03-28-2013, 06:32 AM   #12
Rewards Points: 582
good job ..its just a cap don't over think it ...ben sr
Tags
basement , duct , hvac , return , supply
Plumbing Vents question lynxpilot Plumbing 7 09-30-2012 06:31 AM
Return Vents and Air Handler Question hifiman HVAC 7 04-27-2012 06:44 AM
moving breaker question liquidvw Electrical 1 10-04-2011 03:22 PM
The Bathroom Remodel that just kept growing... (Question 2 of many - Plumbing Vents) gpsmith Kitchen & Bath Remodeling 1 05-30-2011 07:37 AM
