Question On Installing An Honeywell RTH6350 Programmable Thermostat. - HVAC - DIY Chatroom Home Improvement Forum
Old 01-02-2011, 12:02 PM   #1
Question on installing an Honeywell RTH6350 programmable thermostat.
I am switching from a Trane XR401 non-programmable thermostat to the Honeywell thermostat, for my heat pump. The terminal slots differ between the two thermostats. I am checking to make sure the mapping below is correct.
Terminal (Trane) - Function - Wire - Terminal (Honeywell)
R - 24Volt Hot - red - R
W2 - Heating (2nd) - black - E
W1 - Heating (1st) - white - AUX
Y - Cooling - yellow - Y
G - Fan - green - G
O - Switch over valve - orange - O/B
B - 24 Volt - blue - do not use
FYI: here's a link to the Trane install guide :
http://www.butcherdistributors.com/I...0installer.pdf
outdoorted is offline   Reply With Quote
Old 01-02-2011, 03:47 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
do you have electric backup heat?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-02-2011, 06:20 PM   #3
Yes, there are electric coils inside the air handler.
Old 01-02-2011, 06:48 PM   #4
AKA HVACTECHFW
then your wiring should be correct. you may need to jumper E and AUX together if it does not keep temp
IT IS WHAT IT IS
New Honeywell thermostat connected to old Climatrol heat pump olorintf HVAC 0 08-24-2010 09:52 AM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Need help with Honeywell thermostat mmspar HVAC 1 06-29-2010 10:29 PM
Line Voltage Programmable Thermostat for Off-peak studhauler Electrical 4 05-11-2010 04:38 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
