-   -   Question on HSPF (http://www.diychatroom.com/f17/question-hspf-107658/)
markdaviss1 06-14-2011 12:30 PM
Question on HSPF
Hello! I'm considering replacing my electric baseboard heat with hyper-heat mini-split systems. The particular Mr. Slim (Mitsubishi) heat pump I'm looking at has a HSPF rating of 10.55, and heats down to -13 degrees F.
I understand that electric resistance has a HSPF rating of 1.0, but it seems impossible that any system would produce 10.55 times as many btu per watt used. Is it possible? Can/should I expect something like a 90% reduction in my electric usage for heating?
Any info will be appreciated!
Mark
Muncie, Indiana
zootjeff 06-14-2011 05:53 PM
59 Attachment(s)
You are confusing COP and HSPF. Electric heat has a HSPF of 3.41, or your not doing the conversion from BTU to watts.
You take the COP and you divide by .293 to get HSPF. Resistive heat is 1/0.293 or 3.41 HSPF..
COP equals energy moved divided by energy used.
If your HSPF is 10.55, then your COP is 3.09 or 3 times the input power gets moved.. Which is quite reasonable. You should see about 1/3 the energy usage you had before. Resistive heat sucks.
Mark
Muncie, Indiana
markdaviss1 06-14-2011 08:37 PM
Thanks, zootjeff! I actually found that same information (on wikipedia) after creating my original post. But it's nice to have someone confirm for me that I was properly interpreting what I was reading.
And I certainly agree - a HSPF rating of 10.55, for a COP that's (as I calculate it) right at 3 times that of electric resistance, would quickly justify the investment in the more efficient system.
zootjeff 06-15-2011 01:14 PM
59 Attachment(s)
Are you amazed that you didn't do this sooner, or that you didn't know that this was an option? I'm amazed how few people know about heatpumps.. I was certainly baffled when I discovered that I could install a heat pump for 300 bucks more than AC and save 2-300 bucks a year. Why didn't someone tell me sooner?
The contracters that gave me quotes, pushed a specific kind of system and shy'd away from heat pumps.. Lame.
markdaviss1 06-15-2011 02:14 PM
zoot: Ours is a farmhouse built in 1880. It has no existing ductwork. It has been remodeled and additions added several times, so it's your typical old farmhouse, hodge-podge floorplan - some is on a crawlspace, some is on a slab, etc.
I got quotes for anywhere from $12,000 to $16,000 to add central air/heat, with much of that expense going to installing ductwork.
I've known about mini-splits for some time but have been scared off by the fact that they, prior to this new hyper-heat technology, shut down at something like +17 degrees. I knew we'd need to keep our existing electric baseboard, which I was trying to avoid, and to continue to pay for electric resistance whenever the temps got low - and here in Indiana we have several weeks each year when the high temp might only reach 15.
It now appears that I might be able to heat/cool the entire house (currently only partially cooled by two window a/c units) by installing four 23 SEER/10.55 HSPF mini-split units for around $1,500 each. It's possible that I'll experience full payback within 5 years AND pick up a/c of the entire house.
Every few years we might experience one night with an overnight low of less than -13 degrees. If/when that happens, I guess I'll fire up a couple of kerosene heaters to protect the plumbing, and my wife and I will go visit one of the kids!
