Question For Gregzoll - HVAC - DIY Chatroom Home Improvement Forum
Old 06-01-2012, 03:02 PM   #1
Rewards Points: 292
Question for Gregzoll
Gregzoll:
In your response to the thread (A/C not cooling upper floor), you stated:
"We went through and used UV film on all of our windows, and it has cut the heat gain down at least 65%, which allows our home to stay cooler. Also had a attic ventilator installed to help keep the heat gain down in the attic. Both together have helped to keep our cooling costs down."
Could you be specific as to the type of attic ventilator your have? I have full soffit vents front and back, as well as ridge vents, but there doesn't seem to be any airflow (hot as hell up there). I'm not trying to cut costs; just want to get rid of the heat.
Thanks.
V
veesubotee is offline   Reply With Quote
Old 06-01-2012, 10:56 PM   #2
Missouri Bound's Avatar
First of all, I'm not Greg......
But I may be able to answer your question. Attic fans are available in different sizes, based on CFM's. The sq. footage of your attic is the variable you need to determine to choose the proper size.
Do you want it your way or the right way?
Old 06-02-2012, 12:09 AM   #3
Rewards Points: 6,652
It is just a standard power vent fan. Majority are going to be around 1500cfm.
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
