Question To Fully Understand When Heat Strips Engage ... - HVAC - DIY Chatroom Home Improvement Forum
Old 03-07-2012, 09:10 AM   #1
Question to Fully Understand When Heat Strips Engage ...
Hi ...
Recently had 2 Trane XL15i Heat Pumps and Trane Variable Speed Air Handlers installed ... with Honeywell VisionPro IAQ, w/ outdoor sensor, thermostats ...
In the part of North Carolina that I'm in, we usually don't see too many very cold nights ... but can occasionally see 20-30 degree nights ...
I'm trying to fully understand when Heat Strips should turn on ... The VisionPro is set to allow heat strips to turn on with outside temps fall to 35 degrees and below ...
Since installed, we've had a couple nights where the outside sensors for the units show 29 degrees and the home has stayed comfortable ... However, I never see the "Aux Heat On" message or any other notification showing up on the IAQ's screen when this happens ...
Is this because the Emergency Heat will not turn on if the Controller sees that the Heat Pump and Compressor are doing a good enough job keeping the home at the set temperature even if the outside temperature drops below the aux lockout set in the IAQ ...
Just trying to figure out when the Aux Heat should and should not come on based on the IAQ having a lock out set to 35 degrees ...
Tim_in_NC is offline   Reply With Quote
Old 03-07-2012, 02:28 PM   #2
An old Tradesmen
Rewards Points: 7,412
As long as the upstage timer isn't set to bring them on after X minutes. they will only come on when the heat pump can't maintain set point temp. Or if you raise the set temp.
Set lock out temp to 20. If when it drops to 25 the indoor temp starts to drop, you know to raise your lock out to 25 or 30.
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
Heat pump question... thehvacguy HVAC 5 04-06-2011 07:49 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
Easy Heat Pump Question brutis HVAC 6 11-03-2008 10:06 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
