Question About Replacement Parts For A Bryant Furnace. - HVAC - DIY Chatroom Home Improvement Forum
Old 02-24-2009, 07:56 PM   #1
Question about replacement parts for a Bryant furnace.
I have a Bryant 90i 355MAV and the inducer motor has gotten loud. Is there a place to buy just a replacement motor and not the complete assembly? I called the dealer and they want about $1000 to fix it. Ouch! The motor is a GE ECM motor part number 5SME44 JG2001A and another number on the motor is HC23E116.
Thanks,
Sparkey
sparkey is offline   Reply With Quote
Old 02-24-2009, 08:08 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
That unit is a specially balanced and assembled unit with no replacement motor. Those suckers spin at over 3000 rpm and the impeller has to be specially attached at the factory. That unit is very expensive (my cost) and takes up to 2 hrs to replace. My co. would sell it for approx that price.
Old 02-24-2009, 11:13 PM   #3
Sorry, Sparkey. No one will be able to get that part for you. The MFR. of that motor specifically made it for Bryant, sold only to Bryant and Bryant suppliers/dealers, and you won't find it anywhere else.
chard is offline   Reply With Quote
Old 02-25-2009, 05:59 AM   #4
An old Tradesmen
Rewards Points: 6,574
This is why customers should get the 10 year parts and labor warranty.
Old 02-25-2009, 01:32 PM   #5
Hvac Pro
yuri's Avatar
Why the heck did they put an ECM ventor motor in it in the first place? 2 stage furnace so a regular motor who have worked fine and I checked the amps draw and it was the same. Overkill.
Old 02-25-2009, 07:34 PM   #6
Supplier
Hi Sparkey, maybe we can help you, contact us at gsistore and see if the sales can give you a quote.
gsistore is offline   Reply With Quote
Old 02-27-2009, 06:19 AM   #7
gsistore,
I did get a price so thank you for that.
Before I order one of these can someone tell me if it is hard to change? I did see a post in this forum where someone replaced theirs but they had to modify it. See link below post #2.
Bryant Inducer Motor
Thanks,
Sparkey
Old 02-27-2009, 07:32 PM   #8
Hvac Pro
yuri's Avatar
Post a pic of it. If it is the one I am thinking of it is difficult and a real pain in the azz to change. Has a tiny gasket at the back which CANNOT be damaged and needs sealing with RTV silicone. Also very easy to damage the vacuum lines etc. An experienced Bryant guy may be the best choice.
Old 02-27-2009, 09:30 PM   #9
This may be a better picture than I can take because it shows all sides.
http://cgi.ebay.com/Bryant-355MAV-90...3286.m20.l1116
If it would still help, I can take and post a picture.
Thanks,
Sparkey
Old 02-27-2009, 10:52 PM   #10
Hvac Pro
yuri's Avatar
I have replaced several of them and they are quite difficult and I am not exaggerating. I do this for a living and that is one of the more difficult ones. This particular one is used/damaged/patched with white silicone and is junk!! Unless you are a very good auto mechanic who is used to working with delicate items and has good logic skills I would get a Pro to do it. If it then leaks etc a good co. will warranty their work. Not everything is DIY friendly. I can talk you thru it but you may regret tackling that unit.
Old 02-27-2009, 11:09 PM   #11
Hvac Pro
yuri's Avatar
How old is the furnace? Post the serial # and I can tell you. Carrier/Bryant/Payne are all the same co. Where I am most of those units had a 10 yr warranty. Check the owners manual or phone Bryant. You might get it replaced by a dealer and pay the labor.
Old 02-28-2009, 01:12 PM   #12
It's about 7 years old. The SN is 3501A12557 if I have the right number. I found that number on a sticker on the inside left of the furnice.
Sparkey
Old 02-28-2009, 01:39 PM   #13
Hvac Pro
yuri's Avatar
01A = 2001 January. Different areas sold them with different warranties, you need to find that info.
Good Luck
Old 02-28-2009, 03:39 PM   #14
If you can get the CFM specs on the motor, you might be able to find a mechanically equivalent assembly at 10% or 1% of the manuf. cost, but you may have to pay attention to safety in this application.
I'd come up with candidate replacements/ideas and have this forum critique them.
CFM should correlate well to the amp. draw of the motor (supply voltage being equal). Measure the amps and volts while it still works.
You also might want to check pressure/vacuum afterwards to make sure the installed assembly meets system specs. For that kind of bucks you can buy some HVAC test instruments and still make out.
And a starter motor costs $50 but a Harley-Davidson starter motor costs $500.
Old 02-28-2009, 04:13 PM   #15
Hvac Pro
yuri's Avatar
Impossible. That is an ECM, electronically commutated motor which is voltage/speed controlled by the computer/circuit board. Nice idea but gas furnaces are not DIY chemistry projects, and those explode.
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Bryant Plus 90 fuse replacement dgbehrends HVAC 24 11-14-2008 10:51 AM
Furnace Replacement Options? Genhawk21 HVAC 5 01-11-2008 10:41 PM
