Question About My Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 05-10-2015, 03:14 PM   #1
Rewards Points: 82
Question about my thermostat
Ever since I found out that my thermostat is on the same circuit as my furnace I've been puzzled about something. Does that mean that if I flip that breaker off does that mean my A?C wouldn't work? I mean the A/C is also controlled by that thermostat so if that is not on then the A/C would't work right?
Appreciate any thoughts.
lcm1947 is offline   Reply With Quote
Old 05-10-2015, 05:05 PM   #2
Rewards Points: 3,256
That's correct, if the thermostat is powered by 24 volts AC from the furnace transformer. If the thermostat runs on batteries, then no.
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
lcm1947 (05-11-2015)
Old 05-10-2015, 06:57 PM   #3
An old Tradesmen
Rewards Points: 7,786
Most likely your A/C uses the furnace blower to move the cooled air. So you can't shut it off if you want cooling.
The Following User Says Thank You to beenthere For This Useful Post:
Old 05-10-2015, 07:56 PM   #4
Rewards Points: 582
yep no power to t stat means you can't pull in contactor at a/c unit to start it..
Old 05-11-2015, 08:57 AM   #5
Rewards Points: 82
Thanks for the replies gentlemen. I kinda figured that but then thought that that didn't make much sense so just had to ask the question. Now I know for sure. Thanks!
Still seems strange but if that's the way it is that's the way it is.
Old 05-11-2015, 06:22 PM   #6
Rewards Points: 582
welcome ...it is what it is...
The Following User Says Thank You to ben's plumbing For This Useful Post:
Question about thermostat wiring - carrier Furnace and AC Dereks HVAC 2 02-13-2015 11:53 PM
Thermostat question 78Vette HVAC 21 12-22-2014 08:01 AM
question on old thermostat wiring for upgrade jthn HVAC 2 01-02-2011 11:07 PM
Question on installing an Honeywell RTH6350 programmable thermostat. outdoorted HVAC 3 01-02-2011 06:48 PM
Thermostat question ctown HVAC 7 12-05-2006 03:46 PM
