Question About Moving Heating Vent Pipe - HVAC - DIY Chatroom Home Improvement Forum
Old 03-13-2012, 03:12 PM   #1
Question about moving heating vent pipe
I want to redo our small area for the washer and dryer. It is in a closet type area, off the hallway on the second floor. We have natural gas heat and the vent is running in a small area right behind the wall where the washer is. The heater is located in the garage. It is vented all the way to the roof. I want to move a wall and the closet in the bedroom next to the washer closet to expand the area.
My question is: Can this vent pipe be moved or re-routed? Is there a code on distance away from any combustable materials?
I would like to find out more about this before I start taking down any walls.
Thanks for any help! Randy
randalg is offline   Reply With Quote
Old 03-13-2012, 05:02 PM   #2
how
Rewards Points: 1,070
Atmospheric/ 80%/ 90%/furnace???
single walled vent/ B Vent or plastic???
how is offline   Reply With Quote
Old 03-15-2012, 03:15 PM   #3
I'm not sure what all you are asking, I'm no hvac guy. The unit in the garage has a 4-5 inch pipe, looks like galvanize duct pipe to me. This goes through the ceiling, all the way to the roof. It doesn't look big enough to be insulated, but I may be wrong.
I want to know if I can maybe put a couple of 90 degree elbows in the line, so it will not be in the middle of the new closet for the washer and dryer.
Old 03-15-2012, 03:32 PM   #4
REP
If its double walled pipe (called "B" vent) then the clearance is 1 inch to combustable.
Single walled vent pipe is something like 10 inches to cobustables.
You cannot run "B" vent up the outside of a wall unless you enclose it and insulate that chase.
Once to the roof it must be 2 feet above the roof and it must be 10 feet on a level line all around the termination point to any outside wall or the roof itself.
Some places allow a furnace in a garrage but the wall between the garage and house must have a vapor barrier and its questionable that the supply and return duct passes through that wall.
REP is offline   Reply With Quote
Old 03-15-2012, 04:24 PM   #5
Thumbs up
Thanks, REP! I didn''t know what "B" pipe was. Hopefully that's what I'm dealing with. I guess I'll have to open up the wall and see how they have run it. From all the measurements I've taken, there seems to be a 2 ft area where the heat pipe and plumbing is located.
Could I build a chase inside the new closet to close in the ductwork? What about running it along inside the floor joist, if it was insulated?
Thanks!
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 09:14 PM
Bath room vent pipe banovak1 Plumbing 0 04-05-2011 11:24 AM
Water Heater Vent Question pd417 Plumbing 1 05-15-2010 01:34 PM
Vent pipe cover? Ultrarunner2017 Plumbing 2 04-16-2010 07:43 AM
To Vent or not to Vent, that is the question debster Roofing/Siding 5 08-10-2009 05:48 PM
