Question About Mini-split Heat Pump Using R-410a - HVAC - DIY Chatroom Home Improvement Forum
Old 10-05-2010, 12:05 PM   #1
DIY Homeowner
Rewards Points: 79
Question about mini-split heat pump using R-410a
Do all mini-splits (A/C and Heat Pump) have the expansion valve in the outdoor unit? My Friedrich MR18Y3F does, and I wonder why. It makes it impossible to check sub-cooling to verify a proper refrigerant charge. It also makes the small line to the indoor unit a heat absorber before you want to absorb any heat (while in cooling mode). It just seems like a bad idea to someone like me with limited understanding of these things.
Is there another way to check the refrigerant charge on these mini-splits? Please tell me they don't expect you to evacuate and do a complete re-charge whenever you suspect the charge might be low.
BRO931 is offline   Reply With Quote
Question re: Heat Pump tsat wiring cwelte HVAC 10 10-05-2010 07:09 PM
Goodman Heat Pump - Blower Motor FireFighter254 HVAC 9 03-05-2010 06:18 AM
heat pump / BTU question jwalker95 HVAC 3 12-07-2009 06:40 AM
Compatability question (cooling unit to heat pump) Common HVAC 2 10-28-2009 07:44 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
