Question About Gas Burner Design - HVAC - DIY Chatroom Home Improvement Forum
Old 12-14-2008, 10:25 AM   #1
Rewards Points: 682
Question about gas burner design
I recently scavenged an gas valve and burner from an old water heater. I noticed an odd thing in the design of the burner. The gas line does not connect directly to the burner, instead it ends about 2 inches below the burner plate itself. There is a hole in the gas line, and the gas looks like it rises up through open air, hits the burner plate, flows outward to the burner holes at the edge of the plate where it burns.
So the gas is lighter than air and rises up to the burner without any containment at all? It doesn't dissipate in the open air? How come the gas rising in the open air doesn't ignite? Does it need to mix with air before it can burn?
I've noticed the burner in a wall furnace seems to be of a similiar design, with the gas from the gas valve rising through open air before reaching the burner itself.
darsunt is offline   Reply With Quote
Old 12-14-2008, 10:38 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,240
The design of the ports in the burner causes the air to swirl as it rises and mix with the gas and get ignited at the edge by the pilot light. Uses a venturi effect as well as natural draft.
Old 12-14-2008, 12:44 PM   #3
NG needs 1015 degrees and between 5%-15% concentration to ignite. Venturi systems are common and normal.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 12-14-2008, 01:10 PM   #4
Hvac Pro
yuri's Avatar
1100 posts. WOW. You guys keep busy. I did over 2000 in several years at H***Mech B4 the spammers killed it. Lots of talent here.
Cheers
Old 12-14-2008, 01:37 PM   #5
Cheers
It's a great site. I tell all my friends about it.
Detached Garage: Design Question esemrick Building & Construction 4 01-12-2010 04:59 PM
lighting circuit design question amakarevic Electrical 15 10-31-2008 02:11 PM
closing in porch stairs - design question wombosi Carpentry 3 10-12-2008 10:18 PM
Main panel design question amakarevic Electrical 13 06-04-2007 04:35 AM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 05:44 AM
