Question About Gas Boiler Shutoff - HVAC - DIY Chatroom Home Improvement Forum
Old 10-12-2010, 11:28 PM   #1
Just call me Andrew
Rewards Points: 1,020
Question about gas boiler shutoff
Just a question to fill my curiosity...
When you shut off a gas boiler via the emergency shutoff at the top of the stairs, what stops gas from just pouring into your house? Does the lack of electricity cause the valve on the gas line to close?
Andrew
secutanudu is offline   Reply With Quote
Old 10-13-2010, 04:36 AM   #2
An old Tradesmen
Rewards Points: 6,900
Most modern gas valves require 24 volts to open them. So when you turn that switch off. The transformer is de-energized, and can't provide voltage to open the gas valve.
The Following User Says Thank You to beenthere For This Useful Post:
secutanudu (10-13-2010)
Old 10-13-2010, 05:46 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,838
Unless it is an old millivolt/self powered gas burner. Post a pic of the boiler and burner and make and model #.
Old 10-13-2010, 06:39 AM   #4
Just call me Andrew
It's more of a general question....I dont even have a specific boiler in mind. Thanks!
Andrew
Boiler size Bonnie Youngs HVAC 29 07-10-2009 07:58 PM
pilot light on crown aruba boiler mazzonetv Plumbing 1 05-28-2009 10:13 AM
Outside water boiler shutdown hillardl Plumbing 2 03-20-2009 05:27 PM
Boiler Troubles *I Need Help Please* mikerouse1989 HVAC 4 02-01-2009 11:59 AM
Ring Main Question Andyjr Electrical 5 09-14-2008 09:47 PM
