Old 02-29-2012, 09:05 PM   #1
Question about "common" terminal on furnace controller
I'm trying to understand the function of the "common" terminal on the control board of my furnace. Is there a difference between "common" and ground? I thought that the common terminal was another name for ground, but when I measured the resistance between the common connection and the case of the controller I got a very high resistance reading - so apparently common isn't the same as ground. Could someone tell me what the common terminal is supposed to be used for? Thanks.
rvmeush is offline   Reply With Quote
Old 02-29-2012, 09:16 PM   #2
HVAC Tech/ Browns Fan
Look at a transformer it has two wires. Pretend it a train going on one wire. It goes through all the other electrical parts to make them work. But the train need got back to its station ( other wire on transformer) To complete cycle of electric.
Tator1076 is offline   Reply With Quote
Old 02-29-2012, 09:17 PM   #3
Yes I'm been drinking
Old 02-29-2012, 10:33 PM   #4
Part of the Clover Leaf
lol..what the heck kinda Mr. Wizard-Romper Room explanation is that????? ROTFLMAO
I can't even think straight enough to answer the post I'm laughing so hard!
Tator...gimme what ever your drinking dude!HIC-OP~****
hvac5646 is offline   Reply With Quote
Old 02-29-2012, 10:36 PM   #5
Thanks for the analogy - but what I'd like to understand is if the return "track" is supposed to be connected to the overall system ground - e.g. the metal case of the controller housing.
Old 02-29-2012, 10:49 PM   #6
No. It is not connected to the earth grd of the system.
It is like the neutral on a light circuit.
A return leg that the voltage returns thru to complete a circuit when it is energized.
That is over simplified but should answer your question.
The Following 2 Users Say Thank You to hvac5646 For This Useful Post:
ben's plumbing (02-29-2012), rvmeush (02-29-2012)
Old 02-29-2012, 11:16 PM   #7
No is the simple answer I was looking for. Thanks.
Old 02-29-2012, 11:35 PM   #8
how
I think we should offer complete cognitive amnesty to Mr. Rogers for his Hvac electricity/train explanation.
Perhaps in the morning when he's quaffing aspirin to get ready for work, he'll read what he wrote and he'll see the wisdom of separating drinking and social media.
On this side however, the comedic relief was welcome.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
Old 03-01-2012, 12:08 AM   #9
Missouri Bound's Avatar
Then you have come to the wrong place.
Do you want it your way or the right way?
Old 03-01-2012, 05:55 AM   #10
biggles's Avatar
with power up read the R Hot off the TR 24v to ground if you don't get 24V the TR and the board aren't grounded.Common wire on 24Vs is the same as the white/neutral on 115V wiring along with the ground wire serving the same purpose.
Old 03-01-2012, 08:11 AM   #11
Why do you say this? Kind'a harsh...no?
Old 03-01-2012, 08:39 AM   #12
I doubt there are any simple answers on this board, or any board for that matter. Everyone has an opinion, you and I included and simple answers just aren't the usual responses in answer forums. You ask the time and I tell you how to build a watch.
Old 03-01-2012, 10:58 AM   #13
An old Tradesmen
The common terminal is a current return terminal, for devices such as thermostats that need 24 volts to work. And or the A/C condenser.
On some units it will be grounded, and on others it won't be.
It is very similar to a line voltage neutral.
New Furnace & Plenum Install Question rb404 HVAC 3 03-03-2012 12:29 PM
Wiring question for Trane furnace rvmeush HVAC 1 02-27-2012 10:04 PM
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
Lennox 80MGF gas furnace question pdxsk HVAC 16 04-02-2011 02:47 PM
another question for a miller furnace problem jb9270 HVAC 1 02-05-2007 03:04 PM
