Question About Carrier Air Handler - HVAC - DIY Chatroom Home Improvement Forum
Old 08-05-2012, 11:45 AM   #1
Question about Carrier air handler
I have a carrier FB4ANF036 air handler/air conditioning system. I have a boiler system for heat, but it crapped out on me this past year. Considering the age of the boiler (1966) I would rather remove the boiler system in its entirety and replace it with a forced air system. MY question is, is there an option to use my current air handler set-up for heating as well as cooling?
firechicken is offline   Reply With Quote
Old 08-05-2012, 12:16 PM   #2
Rewards Points: 6,652
Just need a a-coil in it. As long as the duct work serves the whole structure, you should be fine.
Old 08-05-2012, 12:26 PM   #3
biggles's Avatar
installing a heat exchanger and burner section might be possible with a fan speed change for heating usually LO/Med LO.if you exsisting supply fan is one speed it would have to be changed....call around for add ons.they will most likely try you to go for new FURNACE with new coil
Old 08-05-2012, 12:41 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
electric strips could easily be added to the AHU as long as you have a large enough electrical service for your home. This would be the cheapest way to upgrade the AHU to serve for heat. However, electric strip heat is expensive to run so you would want to change the a/c to a heat pump and by the time you do all that you might as well have installed a gas forced air furnace with a new evap coil and keep your existing condenser.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 08-06-2012, 12:25 AM   #5
You can get a Heatpump
ResidentialTech is offline   Reply With Quote
Old 08-06-2012, 05:00 AM   #6
An old Tradesmen
Rewards Points: 6,464
Yes, you can get a heat pump to match to that air handler, and have a strip heater package put into it, and use it to heat your entire house. if as said earlier, it has duct work serving the entire house. It may or may not give you as comfortable heat as your boiler system did.
Carrier 58MXA furnace question Jen G HVAC 2 11-24-2010 04:33 PM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 01:52 PM
Carrier air handler model FK4D HK61EA005? mikec57 HVAC 2 10-13-2010 10:26 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Air handler question a12548 HVAC 1 06-25-2008 07:00 PM
