Question About Air Handler Blower Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 08-24-2007, 12:51 AM   #1
Question about air handler blower problem
Hey guys,
Residential Comfortmaker heat pump, about 3 years old. When the ac is operating, or when just the fan is on, the air flow sounds like it drops suddenly to almost zero at the registers. It is not regular and is very brief. This just started recently and the system works fine otherwise. There are no restrictions in the ducts or any other visible problems. It's really hot in Southeast GA, so I need the ac but am concerned about this. Any advice is appreciated.
Thanks,
Ed
whlnut is offline   Reply With Quote
Old 08-25-2007, 09:28 PM   #2
Sounds like a bad terminal connection or somthing that rattled loose, mabey a loose blower door that is flipping the door saftey switch.
shawn T is offline   Reply With Quote
Old 08-27-2007, 01:01 AM   #3
Thanks for the reply Shawn. Yesterday I found several air leaks in the ducting (which is now 19 years old), and a restriction inside one duct. I patched up the leaks and the system seems to be normal now.
Carrier 58MVP Blower Problem mickd HVAC 57 04-11-2017 07:28 AM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Heat Pump blower speed? ktkelly HVAC 1 07-18-2007 10:01 PM
another question for a miller furnace problem jb9270 HVAC 1 02-05-2007 02:04 PM
Furnace Blower Problem SGecko HVAC 2 09-27-2006 10:16 AM
