Old 10-10-2012, 05:01 PM   #1
Quesion about and old house and remote tstat sensors
I have an old house with oil powered hot water heating throughout whole house. I only use 2 out of 10 rooms in the house. There is basically no insulation in the house and all of the windows are single pane glass. I am not allowed to replace the windows or add more insulation so here is what I've done so far.
I turn off the radiators in the rooms I don't use. I figure its best to just heat the rooms I live in.
I am in the process of plastic wrapping all of the windows so that should make a huge difference.
The biggest problem is the fact that the thermostat is in an area that isn't used and is pretty cold. I am not allowed to move the Tstat so to work around this I bought a wifi filterate Tstat that I can remotely adjust from my phone but the setting downstairs will be say 55* in the winter and the upstairs rooms will be 80* and I have to physically monitor the temp all the time.
What I'm looking for is advice on the feasibility of installing a Tstat with some sort of remote sensors so I can keep the Tstat downstairs and have it only monitor 2 rooms and kick on the heat at specified temperatures in only those rooms.
I know Honeywell makes something like this but it's pretty pricey. Anyone have any other suggestions?
Thanks for the help....
xexitenglishx is offline   Reply With Quote
Old 10-10-2012, 06:15 PM   #2
Professional
Slightly cheaper then a honeywell.... Venstar Wireless Residential Thermostat Combo - T1100RF
This would be a good option for you. The receiver goes where your current thermostat is and the wireless stat can be moved to where you want the temperature read.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-10-2012, 06:30 PM   #3
Thanks ill look into that option!
Old 11-19-2012, 09:13 AM   #4
i ended up purchasing the honeywell. I chose it for the expansion and ability to control it from the internet..Thanks for your help
The Following User Says Thank You to xexitenglishx For This Useful Post:
hvactech126 (11-19-2012)
