-   -   Quesion about and old house and remote tstat sensors (http://www.diychatroom.com/f17/quesion-about-old-house-remote-tstat-sensors-159672/)
xexitenglishx 10-10-2012 04:01 PM
I have an old house with oil powered hot water heating throughout whole house. I only use 2 out of 10 rooms in the house. There is basically no insulation in the house and all of the windows are single pane glass. I am not allowed to replace the windows or add more insulation so here is what I've done so far.
I turn off the radiators in the rooms I don't use. I figure its best to just heat the rooms I live in.
I am in the process of plastic wrapping all of the windows so that should make a huge difference.
The biggest problem is the fact that the thermostat is in an area that isn't used and is pretty cold. I am not allowed to move the Tstat so to work around this I bought a wifi filterate Tstat that I can remotely adjust from my phone but the setting downstairs will be say 55* in the winter and the upstairs rooms will be 80* and I have to physically monitor the temp all the time.
What I'm looking for is advice on the feasibility of installing a Tstat with some sort of remote sensors so I can keep the Tstat downstairs and have it only monitor 2 rooms and kick on the heat at specified temperatures in only those rooms.
I know Honeywell makes something like this but it's pretty pricey. Anyone have any other suggestions?
Thanks for the help....
hvactech126 10-10-2012 05:15 PM
Slightly cheaper then a honeywell.... Venstar Wireless Residential Thermostat Combo - T1100RF
This would be a good option for you. The receiver goes where your current thermostat is and the wireless stat can be moved to where you want the temperature read.
xexitenglishx 10-10-2012 05:30 PM
Thanks ill look into that option!
xexitenglishx 11-19-2012 08:13 AM
i ended up purchasing the honeywell. I chose it for the expansion and ability to control it from the internet..Thanks for your help
