Quality Heat Only Programable Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-16-2011, 11:31 AM   #1
Rewards Points: 139
Quality Heat only Programable Thermostat
Searched Home Depot and Lowe's online and could not find the above thermostat. The quality one's do both heat & cooling.The heat only one I saw seem to be of low quality and others were not programable.
If I have to; I will settle for a non programable type or a heat/cooling programable thermostat as long as its quality.
I have an oil burner. What manufacturer and model do you recommend?
My AC works off a separate thermostat.
rjordan393 is offline   Reply With Quote
Old 01-16-2011, 12:11 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
honeywell 6000 stat can be setup for heat only function with or with out fan function.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-16-2011, 12:19 PM   #3
HVAC Installer
Your best bet is to go on-line and look at Granger.com. What you are going to find is heat only stats are not lower quality, but have fuwer functions. However I would recommend that you look through all the digital stats you see and pick the one you like the best. All current digital stats on the market to day can be programed to function as heat only. For my money I would choose a honey well. Good Luck
LukeROttinger is offline   Reply With Quote
Old 01-16-2011, 02:31 PM   #4
Rewards Points: 139
Thanks,
I'll check out Grangers and the Honeywell 6000.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Thermostat went out no A/C or heat mommeetiff HVAC 6 11-06-2010 09:21 AM
An efficient programmable thermostat for a heat pump? mow2000 HVAC 17 01-16-2010 08:09 PM
Heat pump thermostat emergency switch joe913 HVAC 2 12-10-2009 12:54 PM
radiant floor heat thermostat kornbln Electrical 5 03-27-2008 12:45 PM
