PVC Repair Slip Fitting Leaking On A/c Exhaust??, How? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-14-2014, 09:24 PM   #1
Rewards Points: 16
PVC repair slip fitting leaking on a/c exhaust??, how?
HI,
Saw some dripping from a slip/repair coupling from the atrocious builder. Home is 7 years old and this is the first I noticed this.
This is the exhaust PVC to the outside from the furnace/blower/ac, so how is water getting in the pipe, and enough of it to leak?? Basement is 70 degrees...maybe the air cools enough to condense on the inside of the pipe?? The leak is occurring about where the white box is under the pipe.
Can I fix this with just some pvc cement slathered on the outside??
PVC repair slip fitting leaking on a/c exhaust??, how?-img_7570.jpg   PVC repair slip fitting leaking on a/c exhaust??, how?-img_7572.jpg   PVC repair slip fitting leaking on a/c exhaust??, how?-img_7571.jpg
maxim1 is offline   Reply With Quote
Old 05-16-2014, 10:47 AM   #2
Rewards Points: 16
No one has chimed in....
it is a constant drip....
so either way I assume I must let it dry out (turn off the furnace)
then do I buy a 4" pc of pvc and cut it in half and cement next to the leak-slip/repair coupling, or would a glob of cement work just as well?
I have no experience trying to fix a failed pvc joint.
thanks in advance
Old 05-16-2014, 12:16 PM   #3
DIY staff
Rewards Points: 7,174
Cut the bad fitting out and replace---the pitch of the pipe might not be right--condensation needs to be able to drain out of the pipe--
I'll move this to HVAC for you--the heating pros understand this piping well--Mike---
Old 05-16-2014, 03:54 PM   #4
HVAC Tech/Owner
Rewards Points: 604
1. Have to cut out and replace.
2. Flue gases on 90 plus furnaces condense and there has to be a means to drain the water.
3. None of the joints look like primer has ever been put on them-here that is an automatic fail.
4. that's an awful long length of pipe-I hope its within the manufacturer's specs.
Technow is offline   Reply With Quote
Old 05-17-2014, 06:44 PM   #5
Rewards Points: 16
well it apparently passed inspection, but i think the inspector and the builder were buddies.
Drain hole? wont exhaust gases come through a drain hole though?
should the pitch run back towards the furnace?
Old 05-17-2014, 06:55 PM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,534
Maxim... I did not see anyone recommend a drain hole.... but yes...you do not want any leak for exhaust gas in that pipe.
Yes... it slopes back to your furnace, where you should have a discharge tube (3/4" probably) directing it to your floor drain (or a little pump unit and tubeing directing it to your floor drain)
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
oh'mike (05-18-2014)
Furnace Exhaust Making Sloshing Sounds hellonoko HVAC 4 02-15-2013 04:37 PM
Hot water heater leaking from pipe fitting and it seems top as well Omega1986 Plumbing 6 12-15-2008 08:49 PM
Water meter fitting leaking LanterDan Plumbing 6 04-02-2008 10:39 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
Leaking Sink fitting seajay590 Plumbing 3 09-13-2007 08:28 PM
