PVC Exhaust Pipe - HVAC - DIY Chatroom Home Improvement Forum
Old 09-24-2013, 11:44 AM   #1
Rewards Points: 396
PVC Exhaust pipe
Hi,
I have a condensing furnace unit with 2 3" pvc pipes on the exterior. My
exhaust pipe has a street 90 pointing up but no grille to prevent snow, rain or insects from getting in. Any suggestion on what I can use?
detroittigerfan is offline   Reply With Quote
Old 09-24-2013, 01:30 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,092
U cannot put a grill on it or it will freezeup from the water vapor in the exhaust hitting it. Usually they use an open tee or elbow downwards so rain does not pour in. Post a pic of it/them.
Old 09-24-2013, 01:57 PM   #3
Rewards Points: 396
So just a 3" tee fitting?
Old 09-24-2013, 03:01 PM   #4
Hvac Pro
yuri's Avatar
post some pics. you need to follow the manufacturers specs/info but I have never seen it done that way.
Old 09-24-2013, 10:40 PM   #5
Rewards Points: 582
Originally Posted by detroittigerfan View Post
Hi,
post a picture..should not be facing up...ben sr
Old 09-24-2013, 10:44 PM   #6
Rewards Points: 6,652
Just cut the end off, and put a street El (ie 45) facing somewhat down. My guess is that there is a window or vent within the three feet of that exhaust. It should have a slight slope all along the length, that at the end, the outlet is allowing any moisture to go back out of the end, not towards the furnace.
A nice picture far enough back, giving location of how this exits the building, which would also show any windows or vents at the foundation. We can Zoom in if needed for more detail, so no need to take a Macro shot four feet from the vent, or upload a picture that is 1500x1500.
Furnace Exhaust Making Sloshing Sounds hellonoko HVAC 4 02-15-2013 05:37 PM
Cutting and gluing PVC pipe to washer steve3847 Plumbing 8 10-03-2012 09:00 AM
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 09:29 PM
Filling gap between furnace exhaust vent pipe and ceiling tkfd3s HVAC 3 10-26-2010 07:43 PM
2 bathroom exhaust fans to one outside vent pipe? CGofMP HVAC 2 03-25-2005 10:45 PM
