Puzzling Ventilation Shaft In House - HVAC - DIY Chatroom Home Improvement Forum
Old 11-26-2008, 07:02 AM   #1
Puzzling Ventilation Shaft in House
I have a question about my HVAC that I hope someone can help me with.
My furnace room is in the center of the house on the first floor of my two storey house. Next to the gas furnace flue there is a ventilation shaft, approximately 12" x 12" that runs from the furnace room into the attic. Does anyone know what purpose this shaft might serve? Could it be source of fresh air for the furnace to burn, or is it possible that I'm heating my attic (which I don't want to do...)? Should I stick a piece of insulation to plug the vent?
For background, my house was built in 1977 and we had the original furnace until last year, and I don't think that the old furnace used this vent.
jlaky2000 is offline   Reply With Quote
Old 11-26-2008, 09:16 AM   #2
1610 CUB's Avatar
Rewards Points: 150
Could it be a laundry shoot? Hmmm
1610 CUB is offline   Reply With Quote
Old 11-26-2008, 09:23 AM   #3
Rewards Points: 109
It is most likely a fresh air intake for combustion air. Don't plug it up. Ask the installer of the new system to take a look and see if your new furnace is piped with pvc to get the combustion air or if it needs this chase to draw it from the attic. Post a pic of the furnace and it might help. You mentioning the "furnace flue" leads me to believe you need this fresh air supply.
Daltex is offline   Reply With Quote
Old 11-26-2008, 10:58 AM   #4
Yep. Combustion air. You mentioned "furnace room". I gotta assume that is dedicated room just for the furnace? Is there a door on the room?
If so then the duct is a definite must to keep.
hvaclover is offline   Reply With Quote
Old 11-26-2008, 02:55 PM   #5
Smile
Thanks!!!
From what you describe, it is probably a shaft to allow for air for combustion in the furnace. It certainly makes sense. There is a door to the furnace room and no PVC pipes to the outside.
Old 11-26-2008, 04:14 PM   #6
Bwahahahahahahahahahahahahahahahahahaha
Laundry shoot...God one 1610Cub! i sprayed my coffee all over the place!
BTW Happy Thanksgiving if i don't get chance to say it later.
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
EXcessive moisture in house geema HVAC 5 09-10-2008 11:18 AM
Hot Water Heating System in older house GrannyAnnie HVAC 2 08-31-2008 04:50 AM
Re-siding house jdig Building & Construction 5 04-10-2007 09:15 AM
Need advice and assurance on house issues! Leikela General DIY Discussions 3 12-04-2006 10:10 PM
