Old 10-07-2007, 07:38 PM   #1
Putting a new Motor in a Carrier Furnace... Wiring issues
Ok so I got my new motor from the carrier distributor and I wiredit in the way the diagram showed but it won't fire up. Any thoughts on why. My furnace is an HC680005.n DOes this Furnace have a reset that I must push/ Is there a place to get more info on the furnace like a book detailing how to do the job?
-Carter
cbrent is offline   Reply With Quote
Old 10-07-2007, 11:04 PM   #2
There should be a kill switch in the opening, that when the panel is closed, it should feed power to the electrical control circuits.
Old 10-08-2007, 07:04 PM   #3
So I have to close it all up to find out if it works. Okay I will try that. Thanks.
-Carter
Old 10-08-2007, 07:08 PM   #4
You can usually press the switch in to see if it runs, but you are better off putting the covers back in place.
More On This Topic
If you heard that changing spark plugs is an easy task and decided to do it yourself, you can take a few steps that might make your project more successful. The first is to identify the route that the spark plug wire takes. Read More »
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
What is a Distributor Cap?
What is a Distributor Cap? by Expert Village
Hi! My name is Nathan McCullough. On behalf of expertvillage.com, in this clip, we’re going to be discussing what a distributor cap is. A distributor cap is the mechanical portion of the ignition system. It acts as a translator between the rotating... Read More »
Hi! My name is Nathan McCullough on behalf of expertvillage.com. In this clip, we’re going to cover our final visual inspection and test firing of the motor after servicing the distributor cap. It’s a good idea just to recheck your work. It... Read More »
Hi! This is Jon on behalf of expertvillage.com. In this video clip I’ll be talking about the safety switch. The safety switch is located on the front of the planer. To turn it on, what you’ll do is go ahead and flip it up, and to turn it off... Read More »
Need Luxaire Forced Air Furnace Wiring Diagram misticvillage HVAC 7 04-15-2009 05:09 AM
Carrier Furnace - out cold :) cheddarhead HVAC 17 02-27-2007 08:34 PM
another Carrier furnace problem jhrodd HVAC 5 02-18-2007 01:09 AM
My Carrier furnace is driving me crazy hifiuser HVAC 6 02-10-2007 10:48 AM
furnace not putting out heat diff HVAC 1 01-07-2006 12:20 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
