-   -   Putting a new Motor in a Carrier Furnace... Wiring issues (http://www.diychatroom.com/f17/putting-new-motor-carrier-furnace-wiring-issues-12179/)
cbrent 10-07-2007 06:38 PM
Ok so I got my new motor from the carrier distributor and I wiredit in the way the diagram showed but it won't fire up. Any thoughts on why. My furnace is an HC680005.n DOes this Furnace have a reset that I must push/ Is there a place to get more info on the furnace like a book detailing how to do the job?
-Carter
gregzoll 10-07-2007 10:04 PM
There should be a kill switch in the opening, that when the panel is closed, it should feed power to the electrical control circuits.
cbrent 10-08-2007 06:04 PM
So I have to close it all up to find out if it works. Okay I will try that. Thanks.
-Carter
gregzoll 10-08-2007 06:08 PM
You can usually press the switch in to see if it runs, but you are better off putting the covers back in place.
