Put Outside AC Units On Rubber Feet? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-10-2011, 01:20 PM   #1
Rewards Points: 310
Put outside AC units on rubber feet?
Hey all,
I've got a newly finished room in my basement with full-height cement walls on one side. Through that wall is dirt. Sitting on top of that dirt - level with the ceiling of the basement - are 2 AC units. They are each sitting on their own concrete pads which are not connected to the house.
When running - they must shake the ground, where the sound travels throught he dirt, into the concrete wall - and generally into this room. It's just a buzz - but enough to be annoying.
I want to cut down on that sound. Can I lift them up and stick rubber feet or something under them?
denemante is offline   Reply With Quote
Old 05-10-2011, 01:59 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Yes.
http://www.acousticalsurfaces.com/mo...per_w_pads.htm
Doc Holliday is offline   Reply With Quote
Old 05-10-2011, 03:26 PM   #3
An old Tradesmen
Rewards Points: 8,142
Could be the line set that is transferring the noise.
Old 05-10-2011, 05:12 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 380
Those pads absorb a lot of the vibration.
Old 05-11-2011, 01:48 AM   #5
HVAC Supermodel
unicursalhex's Avatar
Rewards Points: 150
Don't use the cork type pads outdoors, they will disintegrate. Use the all rubber or rubber/foam combo. I'm with beenthere on the lineset thing, pads should always go under outdoor units anyway
Mark it zero!
unicursalhex is offline   Reply With Quote
Old 05-11-2011, 06:04 AM   #6
Rewards Points: 1,216
Years ago GE used to put them in the box with the condensing units. Hard rubber like hockey pucks.
COLDIRON is offline   Reply With Quote
Old 05-11-2011, 02:51 PM   #7
Rewards Points: 310
I wonder if those rubber interlocking kids play mats would work - we had furniture on them for a year, and the feet compressed them but not completely. Don't know what would happen though if they are exposed to weather.
I understand the acoustical properties of the first reply's solution.
Anyone know of a simpler, cheaper solution like what I suggested?
Old 05-11-2011, 03:10 PM   #8
It doesn't get any easier then sticking some rubber anti-vibration pads under the unit. Cheaper? Well I suppose you could pick up a junk tire and cut squares instead of buying the pads.
Old 05-11-2011, 03:26 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 380
May cost more for the hacksaw blades to cut thru the steel belts of the tire than the pads.
Newbie needs to build a deck addition toolbot Building & Construction 16 05-10-2011 11:58 AM
rubber gasket donut for cast iron sewer pipe to pvc jbitt Plumbing 6 04-25-2010 12:29 PM
Rubber Roof Sealant ninghai Roofing/Siding 17 03-08-2010 08:58 PM
Patio Flat Rubber Roof installed, and gutter cleaning - ripped off? mark2741 Roofing/Siding 17 03-08-2010 11:55 AM
Stripping rubber padding off a parquet floor nubee Flooring 1 04-22-2007 01:08 PM
