Purging Baseboard Heater System - Bleeder Valves Frozen - HVAC - DIY Chatroom Home Improvement Forum
Old 10-31-2012, 10:09 PM   #1
I have a baseboard heating system in a condo I've lived in for 3 years and until now the baseboard heating system I have has never caused any problems. This past summer I did a couple of projects that required the rerouting of some plumbing, the last of which was a return line for the loop that serves upstairs.
Since I've turned the heater on this year it has all the signs of a significant amount of trapped air - gurgling pipes and a lack of heat upstairs. Below are links for what I'm working with:
http://i1295.photobucket.com/albums/...ps721ff57c.jpg
http://i1295.photobucket.com/albums/...ps9efd18d8.jpg
http://i1295.photobucket.com/albums/...ps12cd2ddd.jpg
Here's the pressure gauge, usually hovers around 12-13 PSI:
http://i1295.photobucket.com/albums/...psde2f572a.jpg
Also, I have two what I believe are bleeder valves in the basement, however they're absolutely frozen - they're at the point where if I go at them anymore it will just strip out the brass...
http://i1295.photobucket.com/albums/...ps2eda49b2.jpg
I feel like the simplest thing for me to do would be just to cut a section of pipe upstairs and install a bleeder valve... I've searched every inch of heater upstairs and down with no bleeders on the radiators themselves and I'm no stranger to firing up the torch - I've done quite a bit of household plumbing work before just never had to deal with one of these systems.
I can basically tell what the inlet/outlet lines are as well as the bypass, I just can't seem to figure out the right order and combination to get this air out of there!!
We live in CT and my wife doesn't take the cold too well... needless to say the quicker a resolution to this problem the happier my house stays. Any help is much appreciated!! If I can provide any other information that's needed please let me know and I'll get it right away.
Thanks in advance!!
jamesbmull is offline   Reply With Quote
Old 11-01-2012, 07:13 AM   #2
Rewards Points: 1,760
can't access pictures.
bob22 is offline   Reply With Quote
Old 11-01-2012, 04:01 PM   #3
An old Tradesmen
Rewards Points: 8,142
Me either.
Old 11-01-2012, 08:07 PM   #4
Rewards Points: 582
3rd that can't access pictures...
Old 11-01-2012, 11:38 PM   #5
frozen as in ice cold frozen or,,, siezed frozen ??
hvac dude is offline   Reply With Quote
Old 11-01-2012, 11:49 PM   #6
Rewards Points: 616
Thanks in advance!!
no pictures.....and you will pure zero air out of something frozen.....
carmon is offline   Reply With Quote
Old 11-02-2012, 09:50 AM   #7
Rewards Points: 446
I'm thinking the bleeder valves in the basement you referred to look like little paddle type handles in a fitting that is soldered into the piping, but have no connection on them for a garden hose........ yes/no? If so these are balancing valves not for bleeding the system. And most are always frozen in place.
Pictures of all the piping near the boiler will help everyone to be able to hopefully tell you if you need to add anything to get the air out of your system. A system that was installed by someone that also has to service it will have what is called purge valves installed that are used to get rid of air from the system. They'll be connections on the piping that you can connect a garden hose to.
old_squid is offline   Reply With Quote
Old 11-02-2012, 12:37 PM   #8
Purging Baseboard Heater System - Bleeder Valves Frozen - PICS ARE FIXED!!
Pics are fixed!!!!!
And to answer Camon and HVAC dude, I did mean frozen as in seized... not frozen as in ice cubes.
Thanks!!
Old 11-02-2012, 12:43 PM   #9
Correct old_squid, no garden hose connections on the mystery fittings in the ceiling of the basement... in the three pics of my system there is however a valve with the garden hose fitting. I was able to bleed some air out of the system out of this valve but when I managed to get 4-5 buckets worth of water out with no visible air I figured that was all that would come.
Old 11-02-2012, 05:24 PM   #10
replace the siezed bleeders if possiable and availabewith auto air vents to start i would recommend
wall heater or baseboard? debiasio HVAC 1 02-08-2011 10:54 AM
Electric Baseboard Heater Problem goombie Electrical 9 12-23-2008 12:13 AM
Help with bleeding baseboard heat system robinswendy HVAC 1 12-13-2008 04:04 AM
Bleeding the Air out of boiler without bleeder valves beetlebabs Plumbing 9 12-12-2007 12:37 PM
gurgling in baseboard heat system jpg HVAC 1 02-22-2007 06:56 PM
