Purged Air From Hydronic Baseboard Heat System, Now Pressure Relief Is Leaking! HELP! - HVAC - DIY Chatroom Home Improvement Forum
Old 10-03-2010, 09:32 AM   #1
Question
Purged air from hydronic baseboard heat system, now pressure relief is leaking! HELP!
Hello again,
A couple days ago I posted this thread, over here. I was set straight on how to purge the air from my pipes after I did some work on the system.
However, after using the manual fill lever on my auto-fill valve and letting the system drain and push the air out of the system my pressure relief valve has started to leak. Unfortunately its a pretty steady drip coming from the pipe.
The pressure shown on the front of the boiler is the same as it was after I purged the system. I made sure the manual fill lever was put back in the off position. I've even tried bleeding off just a small amount of water from the purge valves trying to see if that would help, but the auto-fill keeps kicking in to maintain pressure.
Could the relief valve have failed just from the purge process? Am I over-pressure for the system? Any help you can give is appreciated!
Allan
rodney23 is offline   Reply With Quote
Old 10-03-2010, 09:40 AM   #2
An old Tradesmen
Rewards Points: 6,460
probably had dirt in it. And while you were purging the pressure got to high. And when it opened, the dirt scared the seat.
Needs to be replaced.
About a 15 minute job. including prep time.
Tags
heat , pressure , relief , valve
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
gurgling in baseboard heat system jpg HVAC 1 02-22-2007 07:56 PM
Zone system not working with heat. deliriousga HVAC 5 12-29-2006 07:04 PM
baseboard heat upstairs not working TraceyLee HVAC 1 10-23-2005 06:47 PM
