Old 07-17-2012, 04:37 PM   #1
Cruising into the sunset
JulieMor's Avatar
Purchasing a used condenser...
I had my furnace replaced last fall. I just installed a new Carrier 3-1/2 ton cased coil. All I need now is the lineset and 3 ton condenser to finish the job.
I saw a used Carrier Infinity 3 ton condenser on EBay for $699. It's 5-1/2 years old. The owner says:
Fully functional and removed properly.
5 1/2 years old...it was under a 10yr warranty.(sorry the warranty is not transferable!)
It was pulled from my old house. I planned on using it in my new house but it was not right for it.
So it has been taking up space in the garage and now it's gotta go!
I presently have the Infinity system including the Infinity controller. A new condenser is out of the picture for now due to the cost.
QUESTION: Would you take the chance on a used condenser or sweat it out for the summer?
BTW: the seller has a 100% positive feedback on 264 ratings.
JulieMor is offline   Reply With Quote
Old 07-17-2012, 05:00 PM   #2
I'd pass, and what do you do when it fails, no warrenty, your out of luck.
It's almost 1/2 as old as a unit is expected to last.
Old 07-17-2012, 05:36 PM   #3
Not at that price. Shipping and installation will be expensive and even though the seller says the parts warranty has another 4.5 years that's at the original installed location.
Old 07-17-2012, 06:06 PM   #4
Ditto on the pass. If it were a few hundred, and you could go pick it up then that's different. As it stands, you'll have over $1,000 in it with purchase and shipping - and then you've got to find someone to install a used condenser (which would cost several hundred more dollars in my area). So you'd be very close to $2,000 ... for a used condenser with no warranty.
scottmcd9999 is offline   Reply With Quote
Old 07-17-2012, 06:14 PM   #5
Don't buy someone else's used equipment it's not worth it . Sweat it out or try to buy a new one on payments.
COLDIRON is offline   Reply With Quote
Old 07-17-2012, 06:44 PM   #6
if you have 600.00 to spend now...buy a window unit till you get enough to buy central ..then sell window unit to recoup some cost
The Following User Says Thank You to ben's plumbing For This Useful Post:
COLDIRON (07-17-2012)
Old 07-18-2012, 12:06 AM   #7
JulieMor's Avatar
Kinda did that. I bought a portable 12K BTU. It does a so-so job keeping the bedroom cooler but when it's really hot, like it is now - 91 at 11PM, the bedroom is at 84 so we still need fans to sleep.
I guess I picked a bad year to piecemeal a new HVAC system.
Thanks all for the feedback.
Old 07-18-2012, 12:14 AM   #8
12,000 and it's barly keeping up, somethings wrong or that's one big room.
I had a 20,000 btu that heated and cooled an 800 sq. ft. house.
Old 07-18-2012, 07:31 AM   #9
JulieMor's Avatar
It's a bedroom-bathroom combo with vaulted ceilings and 3 skylights. All total it's about 500 sq/ft. If we close off the bathroom, the unit works pretty well but the bathroom turns into an oven. It has a 44x44 skylight in it and I think that adds a lot to the heat when the sun is beating down on it.
I have heard the portable units don't cool as well as window units. There's one large hose that acts as intake and output both and there's no condensate drain. Somehow the unit evaporates the condensate.
Old 07-18-2012, 07:33 AM   #10
retired elect/hvac/plumb
plummen's Avatar
Turn the blower on for your furnace to help move the air from window ac
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
ben's plumbing (07-18-2012)
Old 07-18-2012, 03:08 PM   #11
you would have been better off to get a window unit....portable as you said so so.....sleep with it beside your bed....
Old 07-18-2012, 04:36 PM   #12
JulieMor's Avatar
That little portable wouldn't be a drop in the ocean and any cooling pulled from the room would be diluted to nothing when it got recirculated back into the house
We have casement windows but in the MBdrm there's only a patio door and two skylights. I was thinking I'd rig up a large hose to have the portable pump air under the covers at night.
When I scrap the old condenser maybe I'll find gold instead of copper then I can buy a new house.
Any Issues: Old Condenser - New System? JulieMor HVAC 3 07-05-2012 08:57 PM
Condenser fan airflow direction?? nicksab HVAC 8 09-20-2011 10:24 PM
Carrier Condenser Unit Screwed? gimmes name HVAC 6 07-24-2011 08:05 AM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 02:54 PM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 07:03 PM
