Pump For A Furnace Question! PLEASE HELP! . VERY COLD LOL - HVAC - DIY Chatroom Home Improvement Forum
Old 12-11-2009, 07:45 PM   #1
Pump for a furnace question! PLEASE HELP! . VERY COLD LOL
Hey everyone/ANYONE who can help me please its cold lol.
K here is my story,
I got a enerplus gas furnace . . the pilot would not light. I had read that the thermocouple might be the problem. I sanded it off put it back in, didnt work. . So I went to canadian tire and got a replacement universal, and I could not figure how to put it in .! . .. On accident I hit a hose that very easily came off and water poured everywhere. I put it back on, I heard water drain someplace.
To my surprise it fired up first click of the ignitor. Only to shut back off as it has done in the past , time and time over again after 10 - 15 minuts of run time. So again, I unpluged this pump (whitch I thought was the actuale furnace plug (lol) but it is only to this little pump. I drained the same hose that I had accidently bumped off the last time. and to my surprise it fired back up first try AGAIN. NEVER HAS IT DONE THAT IN LIKE THE LAST WEEK. . Again it shuts off. . .
SO I repeated the process again to have it fire up a 3rd time. . .NOW MY ULTIMATE QUESTION IS . . Can I leave this little pump unplugged?I believe the furnace will run if I leave this pump unplugged . . or is it bad to unplug the pump ? . I am pretty sure I have found the problem, but why is it acting this way ? . ANy suggestions from anyone that knows what they are talkin about would be greaT!.
So its something to do with that pump or water build up some place. . . help plz n thank you . .
dvandam is offline   Reply With Quote
Old 12-11-2009, 07:50 PM   #2
An old Tradesmen
Rewards Points: 6,892
Post pics.
Sounds like you have drain problems.
Old 12-11-2009, 07:52 PM   #3
man i was just gunna . and my cam ran out of battery S&^%!!! < ,. . . None the less, its been running now 45 min, and 25-30 min of that with the pump plugged in.
I am just scared im really going to wreck it if i keep draining that water. . or keep the pump unplugged
Old 12-11-2009, 07:58 PM   #4
An old Tradesmen
Recharge camera(or get new batteries). Then take and post pics.
Old 12-11-2009, 08:08 PM   #5
have you ever seen a pump for a furnace before? . I am reading online that they are used for air conditioners? . . . You cant say if i am safe to unplug it or not? .
Old 12-11-2009, 08:25 PM   #6
An old Tradesmen
Seen many condensate pumps for furnaces.
But have no idea what pump your talking about from your description.
So, no, can't say its safe, since I don't know what your calling a pump.
Old 12-11-2009, 08:31 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 1,834
Sounds like a Lennox Complete heat or Polaris type unit. Probably has some type of water circ pump thru a secondary coil and NO it is not good to run it now. If it has a closed loop you can damage the pump or overheat the coil etc. It may be airlocked and that is the real problem. Never heard of that brand but may have seen something similar. No reference of it on the net and that is strange. Need some pics of it and the pump as well as age. I suspect that company may be out of business.
Old 12-11-2009, 09:27 PM   #8
camera pics
Here i got my camera working. Furnace is still running goood. 4 degrees an hour aprox. almost hit its hold point at 65.
Pump for a furnace question! PLEASE HELP! . VERY COLD LOL-000_2002.jpg   Pump for a furnace question! PLEASE HELP! . VERY COLD LOL-000_2004.jpg   Pump for a furnace question! PLEASE HELP! . VERY COLD LOL-000_2005.jpg   Pump for a furnace question! PLEASE HELP! . VERY COLD LOL-000_2008.jpg   Pump for a furnace question! PLEASE HELP! . VERY COLD LOL-000_2009.jpg
Old 12-12-2009, 04:21 AM   #9
An old Tradesmen
Can't leave that hose off. You be getting CO from it if you did.
Its probably the crude that is built up it the flue that is stopping the water from draining properly. Pull the hose, clean it out, and make sure the opening in the base of that flue is not blocked.
Old 12-12-2009, 07:48 AM   #10
Hvac Pro
yuri's Avatar
Its a Rheem/Ruud high efficiency unit. That pump is a drainage/condensate pump. Beenthere is correct. You got sludge buildup and that line is not draining properly and backing water up into the furnace and stopping it with a pressure switch. The bottom of the pump is probably full of sludge also and needs cleaning.
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 08:31 AM
Heat pump or high efficiency furnace moisheh HVAC 13 11-14-2010 11:59 AM
Furnace intake noise question joeg679 HVAC 6 12-11-2009 12:03 PM
Help Needed ... turn on circulation pump when furnace in AC mode? Diranged HVAC 12 06-04-2009 06:33 AM
Flooring cold from furnace intake flipper_79 Building & Construction 1 01-25-2009 11:24 AM
