Pulling Out Old Steam Pipes... - HVAC - DIY Chatroom Home Improvement Forum
Old 01-19-2009, 02:18 PM   #1
Rewards Points: 270
Pulling out old steam pipes...
I am trying to make sure I don't by accident take any drain pipes with it. You would think it would be very obvious but most of the basement is finished and some of the pipe diameters appear to be the same.
We have single pipe system. There is clearly a single pipe going to each radiator. That is not really any issue.... they have been easy to identify and i've gotten most of them out already.
There are some other things, like a pipe running around the basement at about knee level.
Theres a steam pipe going across the basement ceiling in a soffit with heat sinks on it. seems like they were trying to heat the basement this way. At the wall it goes down to join up with this pipe running around at knee level. Is that typical of a single pipe steam system?
pcampbell is offline   Reply With Quote
Old 01-19-2009, 04:13 PM   #2
JohnH1's Avatar
Sounds like it may have been a low return or dripper off the header. It was not typical of a residential home. Keep tracing the pipe back to the oridginal boiler. If it eventually ties to the boiler it the heating system.
JohnH1 is offline   Reply With Quote
Old 01-19-2009, 06:20 PM   #3
An old Tradesmen
Rewards Points: 6,470
The one at knee height, is your wet leg.
Old 01-19-2009, 06:24 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 600
Ayuh,...
I'd say That pretty much covers it....
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
Converting steam heat to hot water??? pcampbell HVAC 31 02-17-2009 09:26 PM
Taking out steam pipes... one has asbestos on it pcampbell Plumbing 1 01-12-2009 12:38 PM
New Natural Gas pipes being installed frplymstr Plumbing 12 01-05-2009 02:18 PM
Insulating Steam Pipes Densec General DIY Discussions 5 01-04-2009 10:14 PM
