#1 |
PTAC unit - Heat Won't Work
I have a PTAC unit in my Cabin. The Airconditioning has worked great all summer. This past weekend when i was down there i switched it to Heat just to make sure that the heating was working properly and nothing would turn on. It was in the low 50's at the time with the indoor tempturature about the same as the outside temp.
Later in the day when it warmed up to the lower 80's i turned on the A/C and it worked just time. I only have problems when i switch it to call for heat. I can't even get the blower to turn on. Any suggestions? Could it be a sensor, relay, ?? |
#2 |
First check that thermostat is set to "HEAT" AND that the temperature is set for at least 5 degrees above room temp. which you probably have already done but, just in case..Then see if you have a code flashing at the unit and read manual to see what it stands for..if not..then make sure there isn't a separate switch for the heating side of the unit...
If all that is taken care of then there might be a fuse in the furnace control panel which could be blown and require replacement Also make sure door to fan housing is securely closed ...some times there is a door switch preventing start up if the door is ajar...(the door is NOT a JAR it is a door!!) lol joke.. Back to your problem...are there separate fuses/breakers for the heating side..if so check and reset/replace as required... That's about all I can suggest for now..let us know any more information you can BTW what does PTAC stand for |
#3 |
Professional
PAPPY, a ptac unit is unit like you would see used in a hotel room. It is mounted through the wall. Your suggestions do not make sense for this type of unit.
OP, what is the make and model number of the unit?
IT IS WHAT IT IS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
An old Tradesmen
Packaged Terminal Air Conditioner.
#5 |
OK Gotcha..if I had known what PTAC meant I wouldn't have made the suggestions I did.
So, what should he look for..I'd definitely be tracing the control circuit from the switch onwards but would need the operating/installation manual as well..so, I'm afraid I'm outta here. Anyone else have any advice? |
#6 |
heat pump or electric heat model might help...did you have it in heat or auto and turn the stat all the way up sorry had to ask...could be a s simple as a stat contact.... lets hear back
#7 |
Thanks all for helping. I am heading back down to cabin this weekend. I will try and diagnose/fix. If i am unsuccessful i will come back with the model number.
| The Following User Says Thank You to spbusching For This Useful Post: | ben's plumbing (10-04-2012) |
| Display Modes | |
| $1440+ labor only repair on 3 yr. old Goodman unit!?! | JMK | HVAC | 23 | 05-06-2012 11:45 AM |
| Heat pump starts initially but will not come back on to maintain temps | johnniebravo | HVAC | 53 | 11-22-2011 08:48 PM |
| heat pumps outside unit is broken. | NoraZar2011 | HVAC | 2 | 07-20-2011 09:32 PM |
| Heat Pump will not cut off | sunliner | HVAC | 13 | 05-17-2011 06:38 AM |
| my central a/c heat unit trips my 40 amp breaker after running heat for 5 minutes. | buttons1 | Electrical | 2 | 12-27-2010 10:23 AM |
