Old 02-16-2007, 10:17 PM   #1
Ptac Unit
Does anyone know if they make a wall heat/cool unit that is only 24" wide ?
bdalekid is offline   Reply With Quote
Old 02-19-2007, 03:53 PM   #2
Thoroughbred Mopar Man
Ptac Unit
Hi bdalekid
Most PTAC or PTHP units are 4' x 2' roughly. However there is no reason that you can't build in a window a/c with electric heat that will fit your dimensions. Just make sure you get one with a slip case and the unit has the proper BTU's for your application.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
New A/C unit won't cool in hot temps wishiknewmore HVAC 39 06-28-2012 09:51 PM
can I swap a (3) 60watt unit into a spot where I have a (1) 60watt unit? joeyboy Electrical 11 07-29-2007 08:25 PM
Question on 240v to ac(window unit) evosounds Electrical 2 07-21-2007 12:45 AM
Used Central Air Unit? shep28 HVAC 2 04-21-2007 08:59 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
