Pros A Must See - HVAC - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 08:06 PM   #1
pros a must see
HO tries to repair a Smartvalve
http://www.youtube.com/watch?v=SmQQQ...eature=related
hvac5646 is offline   Reply With Quote
Old 01-18-2012, 06:45 AM   #2
raylo32's Avatar
Rewards Points: 1,284
Good stuff. This is also problem in venues othert than HVAC. For instance if you have a mid-90s GM S10, Blazer, Sonoma, etc and the winshield wipers quit working totally or intermittently, pull the circuit card and reflow the solder joints on the power connector. If the smart valve circuit cards are anything like the GM wiper motor circuit cards 100% of them will eventually fail this way. A bad design (or bad manufacturing run) can cause amazingly consistent (and confounding) failure modes.
raylo32 is online now   Reply With Quote
Old 01-18-2012, 11:48 AM   #3
There are seven parts to this You tube. Very short segments except for acutal dismantiling
Old 01-18-2012, 12:57 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
I watched part 4 which is what you posted and then part 5 but am having trouble finding the next one if there is one. I want to see it fire up after the so called repair.
Help?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-18-2012, 01:26 PM   #5
Help?
It gets fired up in part seven .
Just add a 7 to the written title. Use the seven to replace the four .
here it is for Doc
Old 01-18-2012, 02:02 PM   #6
Thanks. I've replaced quite a few smart valves, not sure I would go through all the trouble to fix the board which indeed the trouble has always been with those main pins.
I guess good for him..?
Thanks.
Old 01-18-2012, 02:45 PM   #7
No more like he should go to jail for reckless endangerment.
He voided every safety certification that valve had by making that repair.
Old 01-18-2012, 03:01 PM   #8
I enjoyed how he went about ranting about "stupid this and retarded that" and "it's a conspiracy theory, we have to pay..!"
However good he must feel about himself, his arguments of "plumming" the valve elsewhere like in the corner or down below where the control board is were ridiculously amusing.
Thanks.
Old 01-18-2012, 04:01 PM   #9
An old Tradesmen
Rewards Points: 7,370
And all it really needed, was the molex pins reset/reseated. LOL
Old 01-18-2012, 04:45 PM   #10
How do you do that?
Thanks.
Old 01-18-2012, 06:06 PM   #11
Been was being facetious..the valve was slagged.
Old 01-18-2012, 06:08 PM   #12
An old Tradesmen
How do you do that?
I was half way being sarcastic. often, a tooth pick will hold the molex connector in a straight enough alignment, that the valve works again.
Old 01-18-2012, 06:15 PM   #13
Yeah. As a temporary fix. Even then the dang thing messes up after awhile.
Old 01-18-2012, 06:18 PM   #14
An old Tradesmen
LOL... Yep, its a smart valve, they never last as long as any other valve.
Old 01-18-2012, 06:19 PM   #15
That's exactly what had happened to the last two smart valves I came across, they had been bribed into place. The first one someone from my company had simply put a wood splint in to hold the plug at a certain angle and it held for one year. I went for the new call this season, removed the splint and it worked for one day.
I replaced that sm.
Other one had the plug forced into place by use of about 5 zip ties. Replaced that too.
Thanks.
Any pros here that can help find a power digging tool? kmc Landscaping & Lawn Care 9 12-24-2011 12:08 AM
Hardwood Flooring Pro's Best Practices Done That Flooring 3 08-22-2011 02:16 PM
Pros vs cons for finished garages mopowers Building & Construction 2 07-24-2009 12:24 AM
Ruud Service Manual, Pros don't want me to understand my system Ruuduser HVAC 56 03-29-2009 06:45 PM
Please explain the pros and cons to gutters. curls00 Roofing/Siding 1 11-14-2007 12:42 PM
