Pros & Cons On Toe Kick Heaters? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-03-2010, 12:16 PM   #1
Mopar Man
shhnappa's Avatar
Pros & Cons on Toe Kick Heaters?
I've narrowed it down to these two units for my kitchen remodel. This will replace my existing baseboard heat. I can't seem to see any real differences except maybe a little in the install dept. I wanted to hear from any of you that may have installed and used these to hear your comments, and hopefully push me in one direction or the other. Thanks for the feedback.
Myson | Whispa III 9000
http://www.shophmac.com/myson-whispa-iii-9000-ez.html
Smith's Environmental Products | Quiet-One KS 2010 |
http://www.shophmac.com/quiet-one-ks-2010.html
shhnappa is offline   Reply With Quote
Old 02-03-2010, 12:21 PM   #2
Joe F's Avatar
Rewards Points: 294
I had a Beacon-Morris kick space heater in a bathroom. It was a little too loud and the heat output was lacking. Wound up getting rid of it.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 02-05-2010, 10:40 PM   #3
Mopar Man
shhnappa's Avatar
Anyone else have any input?
Old 02-05-2010, 11:23 PM   #4
An old Tradesmen
Rewards Points: 6,500
One toe kick is about the same as the other.
Some have higher quality fans. Usually, they are the more expensive ones.
Just remember, a toe kick must be installed as a mono flow if you want it to heat right.
Old 02-06-2010, 08:19 AM   #5
tk03's Avatar
Rewards Points: 150
They are normally noisy after a year or two and gather mucho dirt. The fans need cleaned usually every other years unless you have pets. Most will give good heat providing they are piped as Beenthere states.
tk03 is offline   Reply With Quote
Pros vs cons for finished garages mopowers Building & Construction 2 07-24-2009 01:24 AM
rewiring garage, questions about conduit pros and cons wombosi Electrical 32 05-08-2009 02:59 AM
purple martin/bat house pros and cons? DangerMouse Pest Control 12 01-15-2009 08:25 AM
Toe Kick Heaters MikeyP HVAC 1 12-07-2008 01:03 PM
Please explain the pros and cons to gutters. curls00 Roofing/Siding 1 11-14-2007 01:42 PM
