Proper Technique? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-01-2010, 11:51 AM   #1
Rewards Points: 292
Proper technique?
In another forum, it was suggested that without using gauges, a homeowner could determine if charge was low by 'taping' thermometers to the high and low lines and recording the individual temperatures.
I am familiar with the principles of SH & SC and realize that pressure readings are required. Is there any way that proper charge can be determined by using the 2 temperatures, only?
V
veesubotee is offline   Reply With Quote
Old 05-01-2010, 12:25 PM   #2
even simpler take supply air temp vs. return air temp if you have 16 to 20 degrees differance your likely ok
kennzz05 is offline   Reply With Quote
Old 05-01-2010, 12:35 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,102
16 is not uncommon with the more powerful ecm blowers in new furnaces. I get a LOT of them running 16 degF Delta T and 18-20 on the old school units with fixed orifices and slower and smaller fans. The only correct way to charge a system accurately is by weighing in the charge according to line length and manufacturers specs. Reading a superheat or subcooling chart the manufacturers always factor in +/- values so using thermometers is never going to be 100% accurate. Works well enough 95% or more of the time but TX valves modulate and lines temps modulate with it. Airflow and cleanliness or both coils can affect the readings. Beer can cold can be usefull also.
Old 05-01-2010, 02:17 PM   #4
An old Tradesmen
Rewards Points: 6,088
With the large number of approved coil matches to outdoor units. And the effect it has on operating parameters.
Line temps alone. Are about as accurate as holding your hand over he closest supply register.
EG: 85 outdoor temp. 78 indoor temp.
52 vapor line, 95 liquid line temp.
Is it an under or over charged 10 SEER, or an over or under charged 14 SEER.
Old 05-01-2010, 05:24 PM   #5
Rewards Points: 292
No information given, except that unit is not cooling.
Looking at your (example) temps, I'm guessing they are meaningless.
V
Old 05-01-2010, 06:36 PM   #6
An old Tradesmen
Yep, they are pretty much useless. They are the line temp readings from a slightly under charged 14 SEER A/C though.
proper material for service grounding rod? Jim S. Electrical 9 02-05-2009 10:25 PM
How to remove a technique I did to my kithen walls ekolp Painting 5 12-31-2008 05:55 PM
Texture technique Txmomof2 Painting 4 02-10-2008 09:14 PM
Proper inside framing/insulation/vapor barrier technique trevorjwilson Building & Construction 1 11-20-2007 06:21 AM
Help! What is Proper Way to Install Manufactured Stone? EricW Building & Construction 3 01-07-2007 04:56 PM
