Old 06-25-2009, 04:13 PM   #1
Proper Tape for Holding Reflectix
I am trying to insulate my garage door so my 12K btu a/c will keep up. I have applied Reflectix foil insulation using carpet tape. It has plenty of grip until it heats up...then it gets very gooey and the insulation sags. A couple of sections have fallen off completly.
What type of tape or adhesive would give me a better bond that would hold up to the 100 degree plus metal surface? I'd like to have some chance of removing it at some point.
Peace,
Mark
guitarnut is offline   Reply With Quote
Old 06-26-2009, 02:28 PM   #2
I used mounting tape from 3M. Then taped all the edges with foil tape. It's buttoned up tightly now.
http://www.crenshawweb.com/door.htm
Peace,
Mark
Need advice on roof heat tape. marchboom Electrical 52 12-04-2011 04:45 PM
using caulk instead of tape on hairline cracks.. windowguy Painting 2 04-15-2009 11:27 PM
Proper tape for underlayment seams eis61374 Flooring 1 01-20-2009 01:28 AM
drywall tape coming off jlajla24 Drywall & Plaster 5 12-04-2008 10:27 PM
Drywall Mudding - Tape Lifting Drywall_Dummy Building & Construction 5 09-06-2005 12:53 PM
