Old 11-15-2008, 10:37 PM   #1
Default Proper installation of register boot
I am about to start installing registers in the ceiling of my house. The house has plaster not drywall. I am wondering what the proper way is to install the flanged boots. Do I simply sandwhich the plaster between the register and boot to hold everything in place or is it a requirement that they are fastened to a ceiling joist.
hartkem is offline   Reply With Quote
Old 11-15-2008, 10:50 PM   #2
not a requirement but it sure makes it easier bend 1/2 flange all the way round so theres something for the reg. to screw into
kennzz05 is offline   Reply With Quote
Old 11-15-2008, 10:53 PM   #3
Yes, you can just screw the register to the boot and it will hold it in place. During new construction you would use boot rails to hold the boots in place.
You will need a friend to hold the boot in place while you screw the register in. If that is not an option, you can screw drywall screws into the boot to hold it in place. Just make sure that the register covers them up.
bluefitness is offline   Reply With Quote
Old 11-15-2008, 11:51 PM   #4
So I don't have to attach the boot to a joist? The plaster is enough?
Old 11-16-2008, 12:11 AM   #5
Yes..
Old 11-16-2008, 12:44 AM   #6
Ok that makes things easier. Is there a preferred location for the supply ducts. I will have one return in the center hallway in the house. I was going to simply install the ducts on the outside walls.
More On This Topic
What Is Drywall?
What Is Drywall? by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be answering the question what is drywall. Drywall is a construction product that is commonly used to finish the interiors of buildings. Since it was invented, it revolutionized the... Read More »
A plasterer applies plaster to various surfaces to achieve different effects. A skilled plasterer not only applies the plaster, but textures and custom finishes as well. Learning to become a plasterer requires math skills, blueprint reading and physical... Read More »
How to Find Total Duct Loss
How to Find Total Duct Loss by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Solutions. On behalf of Expert Village, we are going to do a duct test in this house. Now we are looking for the total loss even the loss to the inside, even the loss where our tape might be leaking or... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
Hi my name is Nat McCullough on behalf of expertvillage.com. In this clip we are going to talk about the proper way to reassemble your strut assembly. What we have here is our strut and we are going to take and install the lower spring perch. As you... Read More »
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 02:19 AM
round ceiling registers installation jp1953 HVAC 1 04-11-2008 11:32 PM
Install Register Boot in finished ceiling? rockyfan206 HVAC 1 03-06-2008 07:26 AM
Molding over heat register patrickosu Remodeling 4 02-16-2008 01:07 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 09:46 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
