Proper Installation Of Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 08-30-2012, 11:11 AM   #1
Proper installation of heat pump
I have a barely 2 year old completely new 15 SEER heat pump/ air handler that had not been cooling well. I set up a service call with my installer. Turns out I had a loose fitting on the metering tube on the indoor TXV. My technician said that the problem was "factory related", and added 2 pounds of R410A. My repair expense was $271.
My question is, should this connection have been checked at the time of the install, and is this repair fee reasonable?
albag is offline   Reply With Quote
Old 08-30-2012, 11:21 AM   #2
Normally that would have been caught during the initial set up, he should have done a pressure test before releasing the freon. Between the pressure test and the vacuum the leak should have been found.
Affordable Comfort, assisting with furnaces Barrie and surrounding area, as well as offering 24 hour furnace repair
Acomfort is offline   Reply With Quote
The Following User Says Thank You to Acomfort For This Useful Post:
plummen (08-31-2012)
Old 08-31-2012, 07:27 PM   #3
Thumbs up
Response to Acomfort
Thanks, Acomfort, for your quick and honest response.
I am tired of contractors that don't stand behind their work and/or suppliers. I have already spoken to my installer, who has agreed to accept whatever amount that I deem fair as full payment. Your response has made it much easier to arrive at a figure that I believe is both fair and reasonable.
I wish you well in life and your future business endeavors.
Thanks again,
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
Disable heat pump in a carrier infinity hybrid (dual fuel) system? andrewket HVAC 0 12-05-2011 04:30 PM
Heat Pump Crisis, Help! Doc Holliday HVAC 14 12-02-2011 09:22 PM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 05:38 AM
What did I do? Heat Pump isn't working ChrisDIY HVAC 10 03-14-2011 03:55 PM
