-   -   Proper installation of heat pump (http://www.diychatroom.com/f17/proper-installation-heat-pump-155314/)
albag 08-30-2012 11:11 AM
I have a barely 2 year old completely new 15 SEER heat pump/ air handler that had not been cooling well. I set up a service call with my installer. Turns out I had a loose fitting on the metering tube on the indoor TXV. My technician said that the problem was "factory related", and added 2 pounds of R410A. My repair expense was $271.
My question is, should this connection have been checked at the time of the install, and is this repair fee reasonable?
Acomfort 08-30-2012 11:21 AM
Normally that would have been caught during the initial set up, he should have done a pressure test before releasing the freon. Between the pressure test and the vacuum the leak should have been found.
albag 08-31-2012 07:27 PM
Response to Acomfort
Thanks, Acomfort, for your quick and honest response.
I am tired of contractors that don't stand behind their work and/or suppliers. I have already spoken to my installer, who has agreed to accept whatever amount that I deem fair as full payment. Your response has made it much easier to arrive at a figure that I believe is both fair and reasonable.
I wish you well in life and your future business endeavors.
Thanks again,
Albag
